Home > General > Whining sound when I turn the interior fans on |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
The ECU has a cooling fan and that is on the passenger side of the car against the firewall in the engine bay.
Thu Nov 25 2021 10:01pm |
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 |
Hmm it might be the latter then.
Mon Nov 29 2021 12:07pm |
I suppose you could pull the FBH's fuse so it won't run and see if the noise persists. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 29 2021 12:18pm |
What does FBH mean? |
Mon Nov 29 2021 4:01pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 408 |
Fuel Burning Heater - I think. Barrie.
Mon Nov 29 2021 4:46pm |
Thanks |
Mon Nov 29 2021 4:59pm |
Sorry, yes, it's the auxiliary heater that runs on fuel to help heat the coolant in cooler weather conditions. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 29 2021 6:12pm |
Yep, it must be the FBH then guys.
Tue Nov 30 2021 1:14pm |
Good stuff - thanks for the feedback as it helps the next one. 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 30 2021 7:46pm |
