Home > Maintenance & Modifications > Best Brake Pads? |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Can somebody please advise on the best pads to replace the existing (Ferodo?) on a standard diesel HSE? Im not sure if EBC manufacture any compatible greenstuff options, and been advised Mintex are a vastly superior choice? Also, do grooved (& drilled?) discs help and where can they be obtained (USA?). Anything must be better than the wooly originals!!! Thanks fellas. |
Thu Oct 12 2006 4:42pm |
Berliner Member Since: 04 Oct 2006 Location: Berlin Posts: 34 |
Have you tried Brembo? |
Thu Oct 12 2006 5:04pm |
No, not yet. It would be extremely expensive to change to Brembo calipers, discs, pads, boosters, lines, etc, and thought upgraded pads and/or discs might be worth a try first? Ive read several RRSport reviews on Brembo with mixed outcomes so Im not entirely sure it's worth it. This is only for routine stop-start road use, not high performance, so there must be some low-budget options. The present factory combination is NOT good. Your thoughs please? Thanks! |
Thu Oct 12 2006 6:55pm |
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 |
Here is an excellent resource, and I speak with many years experience of Bob Green with both high-performance road cars and racing sports cars
Thu Oct 12 2006 9:59pm |
Thanks for the advice. Im sure Brembo aren't wooly, just the standard diesel set-up which has smaller discs, less-effective calipers and Ferodo pads. Im just looking to sharpen-up the response without spending a fortune and hoped that different pads might do it?? |
Thu Oct 12 2006 10:12pm |
