Home > Technical > 2 Concerns L320 - any help please |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 |
Wheel bearing? |
Wed Oct 27 2021 7:16pm |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Thanks. It's just passed the Mot. Are they harder to diagnose than other cars? |
Wed Oct 27 2021 8:32pm |
H2OOW Member Since: 15 Dec 2020 Location: Torquay Posts: 3 |
I fought with the same issue, it turned out to be a buckled wheel. 2012 SDV6 HSE Lux |
Thu Oct 28 2021 9:52am |
Thanks, will get them checked 1st then look at the wheel bearings. |
Thu Oct 28 2021 10:52am |
So I had the wheel balancing checked, swapped with the rears and the issue is the same..
Mon Nov 08 2021 9:55am |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 62 |
I had similar and it was that the rear brake caliper had seized
Mon Nov 08 2021 3:16pm |
Thats interesting. Ill check the heat on the rear brakes after a run later. |
Mon Nov 08 2021 3:53pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
I've had the same issue and mine was a sticky caliper well. Also had an out of shape wheel but that only caused a very slight steering wheel vibration at 50-60 mph. 2010 RRS, TDV8
Mon Nov 08 2021 4:04pm |
Thanks, was yours a rear too? if I brake and get the wobble then let off the brake it stops immediately. and doesnt pull at all either direction. I can rule wheels out now. I know there is a slight bit of play in bottom arms so will inevitably change them or upgrade but dont feel they are involved in the wobble. I guess all that's left is the brakes (rear calipers to check) and im paranoid that the front discs are Pagids and not LR, also the wheel bearings to check but no abnormal noises from them. |
Mon Nov 08 2021 4:18pm |
I think it might have been,, was found by accident if I recall,,,, had asked the handbrake to be cleaned out and adjusted correctly during a service and they found the sticky caliper when taking the discs off. I don't think I would worry about the lack of genuine brake discs,, other options available, I've used borg and beck brake parts many times,, good quality at a good price. 2010 RRS, TDV8
Mon Nov 08 2021 4:51pm |
Thanks Gogsy, it was more that I have read over and over since the last few days that only LR discs should be used due to non OE parts warping easy - so thought that could be it, |
Mon Nov 08 2021 5:12pm |
by way of an update, I have fitted new Polly bushes to the bottom arms up front and new LR bottom ball joints. most of the play has gone, the hydra bushed were well shot but passed the MOT??????
Tue Nov 23 2021 10:25am |
Scotty1980 Member Since: 08 May 2022 Location: Somerset Posts: 30 |
Hi Crraigymmmmm
Tue May 24 2022 1:43pm |
Hi Scotty, After the bottom arms, I went for a 4 wheel alignment and changed the budget tyres that came with the wheels for Pirelli's - all sorted now! so I dont know if it was the tires or the balancing but all cured! however the bushes made the biggest difference, and the tyres made it perfect - if that makes sense.
Tue May 24 2022 2:15pm |
