Home > General > Paddle Shift Question |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4867 |
No it does not need to be in sports mode.
Fri Oct 29 2021 11:16am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Works in either mode D or S. Can be selected by pulling one of the paddles, can be put back in to auto mode by holding the up paddle for a few seconds, or it will revert to auto mode if no paddles are used for a period of time.
Fri Oct 29 2021 12:22pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1759 |
Wow! 7777 posts! 2023 P440e SE Dynamic on order -cancelled
Fri Oct 29 2021 12:47pm |
And most of them total rubbish!
Fri Oct 29 2021 2:54pm |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
So will I just need a new steering wheel with the paddles and have the CCF edited?
Mon Nov 01 2021 2:27pm |
What model of RRS do you have? I think the paddle shift only became available with the 8-speed gearbox. No doubt, someone will have figured out how to add it to non-paddle shift vehicles, however. 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 02 2021 4:38pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 757 |
When I was looking for mine, I viewed several MY10's with the 6 speed box with paddles, albeit mine doesn't have them. |
Tue Nov 02 2021 8:18pm |
My S/C which still had the 6 speed box has them although that's a MY13 car, never bother using them though.
Tue Nov 02 2021 9:28pm |
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 79 |
My 2010 V8 with a six speed box has them, I haven’t got round to playing with them properly yet, only by accident when I catch the paddle by mistake. 2010 HSE TdV8 in Stornoway Grey.
Tue Nov 02 2021 11:09pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
I use them when I want to pretend I'm driving something sportier ..
Wed Nov 03 2021 11:33am |
I generally use the paddles to force the gearbox to change down properly at roundabouts / junctions. In auto mode, it's usually messing around in 3rd or even 4th at 10mph having slowed down from speed, meaning roundabouts and junctions can be a lottery if you try to judge a gap and roll in to it. Sometimes the throttle does nothing for a second or two, or three, or four as the gearbox is way too high a gear.
Wed Nov 03 2021 12:23pm |
Ah .. interesting you say that; I always wondered if the occasional pregnant pause pulling away at junctions or roundabouts was 'just mine' or all of them.. I've nearly been caught out a few times (especially out of our road in Spinney Hill onto the Kettering Road) and I've wondered if I might be better off having the gearbox in Spanish waiter mode.
Wed Nov 03 2021 12:29pm |
Junction pause? They all do that sir. Sometimes known as the suicide pause.
Wed Nov 03 2021 1:08pm |
Suicide pause yep that sounds accurate! It also means that I jump back in the wife's car (R56 Mini Cooper S) which is also automatic and kangaroo off like a learner because the throttle pedal is the polar opposite in terms of sensitivity from a standstill.
Wed Nov 03 2021 1:21pm |
