Home > Tips & Tricks > ACE Filter replacement
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi just a general query has anyone replaced the filter in the block I think it’s supposed to be changed at 75000.
My RRS is a 2013 63000 on the clock but I’ve heard that the plug that fits into the alloy Ace valve is a harder metal and you could end up with damaged threads leading to a leak !!!!.As ever any wise words appreciated. Bow down Bow down
Post #614590 Wed Jun 09 2021 7:11pm
knwatkins
That is true so don't over tighten the nut.
It's a simple job to replace the filter. Just drop the old one out and pop the new one in. Kev
Post #614595 Wed Jun 09 2021 7:46pm
Iomegas
Thanks Kev I’ve got the Torque settings for it so it should all be good lol i hope 🤞 lol
Post #614598 Wed Jun 09 2021 8:10pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
There is an O ring on the nut so make sure your new filter comes with that too.
Post #614641 Thu Jun 10 2021 7:40pm
Iomegas
Thanks Nilrem appreciate your reply i wire brushed around the housing today and sprayed some penetrating fluid onto it for good measure .
Post #614644 Thu Jun 10 2021 8:31pm
knwatkins
 Kev
Post #614647 Thu Jun 10 2021 9:09pm
Iomegas
Bow down 3 Thumbs Up
Post #614648 Thu Jun 10 2021 9:16pm
Rather than use screwdrivers to lever old filter out, there is actualy a thread in the base of the filter which you can screw a 6mm treaded bolt into to wriggle it out with if you wish. Little easier if you happen to be laid on the floor doing it.
Post #616459 Sat Aug 07 2021 5:45am
Iomegas
Hi great advice appreciated cheers.
Post #616461 Sat Aug 07 2021 8:28am
I bet LR have a special tool for that. Probably available at the cut-price cost of just a single kidney. Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #616463 Sat Aug 07 2021 11:43am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Filter Replacement
I change my filter every year. It might be a bit of an overkill, but I have never had a problem with the system after 11 years. It is cheap insurance as they are cheap enough.
Post #617396 Fri Sep 17 2021 3:01pm
Iomegas
Hi thanks for your comments I take it you haven’t had any problems with the threads of the alloy housing when you put screw the cap back in ?
Post #617403 Fri Sep 17 2021 5:23pm
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
has anyone replaced the fluid in the ACE system?
is it worth doing?
Thanks! 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #617581 Wed Sep 22 2021 2:11pm
knwatkins
Yes. The official procedure to drain the fluid is via the fitting on the ARB itself. Mine was rusty so I didn't want to touch it and risk rounding and/or leaks. It's much easier to do multiple drain and refills directly from the reservoir to switch out the black horrible fluid for nice clean stuff. Kev
Post #617603 Wed Sep 22 2021 6:45pm
knwatkins
 Kev
Post #617616 Thu Sep 23 2021 7:08am
