Home > General > RRS 2010 facelift rear spoiler |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4808 |
Update you profile!
Tue Jun 01 2021 10:43am |
Bazzer58 Member Since: 13 May 2015 Location: Cornwall Posts: 13 |
Thanks.
Tue Jun 01 2021 11:24am |
I don't.
Tue Jun 01 2021 11:29am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4866 |
You need to look under the head lining at by the top of the tailgate, if you look at the the two connectors marked if there are wires in pin no's 1 & 15 (co-ax type cable I think as goes to the front touch screen, in plug C0144T and pin's no's 8 black wire (earth) & pin 9 green wire (live) in plug C2739T then you may already have the wiring if no wires in those positions then probably not, you will also need the link wire LR016142 unless you manage to buy a rear spoiler with the camera and lead still attached. The basic wiring circuit is quite simple and straight forward as no control module involved only front screen.
Tue Jun 01 2021 9:44pm |
Thanks very much for the info.
Wed Jun 02 2021 10:46am |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Camera upgrade aside, why do you need a replacement spoiler? My one started to delaminate (first noticed as it was causing a rattle when closing the boot lid) but it was a very simple job to remove it and re-bond the two halves together with appropriate adhesive. 2010 TDV8 - current - my first RRS, loving it so far......
Thu Jun 03 2021 3:29pm |
Could be apart from the A/B variant there were two different spoilers fitted, one with camera aperture and one without, as the O/P has a SE it may not have the provision in the spoiler for a camera.
Thu Jun 03 2021 10:54pm |
I have just purchased a replacement spoiler from China.
Thu Aug 19 2021 1:17pm |
Top part of the spoiler has been re deployed to somewhere on a motorway. |
Thu Aug 19 2021 1:19pm |
Bracket LR023566
Fri Aug 20 2021 9:03am |
