Home > Faults & Fixes > Fragments in oil filter |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 |
If you still have the old oil get it sampled in a test lab, having the material identified is a starting point. |
Mon Aug 02 2021 8:50pm |
Range78 Member Since: 01 Feb 2019 Location: Guyancourt Posts: 19 |
I did not collect the old oil but I did recover the filter. |
Mon Aug 02 2021 10:33pm |
Try flushing the filter with new oil with the hope that small particles of material in the filter is captured in the sample and tell the lab to identify? |
Tue Aug 03 2021 9:12am |
Yes very good idea, I will also help myself with a brush.
Tue Aug 03 2021 11:09am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Personally, I wouldn't drive the vehicle.
Tue Aug 03 2021 1:00pm |
I have no other car and my vacation is booked.
Tue Aug 03 2021 9:59pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 870 |
Aluminium ??? Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S |
Wed Aug 04 2021 10:08am |
Yes is possible, coming from the cylinder head? |
Wed Aug 04 2021 12:44pm |
The glitter could be white metal from crankshaft bearings, get it tested. |
Wed Aug 04 2021 1:08pm |
Doubt its from the head, but as stated white metal bearings is possible, could be lots of things but I think it would be pretty noisy. I would not like to be using it until you get a diagnosis or at least get another oil change or at least a filter change to see if the new filter has anything. If nothing, then it gives you peace of mind for your holiday. You don't want it to be a really expensive holiday. If draining the oil check the drain plug for swarf as it may have a magnet on it (oh your particles are non magnetic, forget that) Good luck Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S |
Wed Aug 04 2021 1:54pm |
Is this metal attracted by a magnet? |
Wed Aug 04 2021 2:13pm |
You are right, I would like to disassemble the filter myself, but I am afraid I will not be able to put it back correctly. Especially at the level of the nipple. If you had a procedure? |
Wed Aug 04 2021 2:16pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8873 |
No. White metal is an alloy of tin, lead, zinc and maybe some other stuff like bismuth. None of the constituents are attracted to a magnet. The backing of the bearing is usually steel which would be attracted to a magnet. I'd be concerned that a bearing was breaking up. That's going to be a new engine (or at the least a rebuild) if you drive it and the crank snaps. Best advice to not drive it until you have established what the metal is and where it's come from. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Aug 04 2021 4:05pm |
Wed Aug 04 2021 6:36pm |
