Home > General > Anti roll bar removal without lifting the shell
eddyeggs
Hi does anyone know if a new ACE bar can be fitted at the rear of a 2010 range rover sport without the shell being lifted
Post #615795 Thu Jul 15 2021 10:13pm
I believe it has to be lifted a bit (a couple of inches or so) although it doesn't require the whole body to be fully removed. 2012 SDV6 - it's missing a couple of cylinders
Post #615798 Thu Jul 15 2021 10:56pm
eddyeggs
Hi , so the question is can the body be lifted without a 2 poster lifter can it be done while on the floor
Post #615801 Thu Jul 15 2021 11:04pm
No idea, I'm afraid as I've never done it. I believe some have done it at home so presumably it is possible with a suitable jacking device. 2012 SDV6 - it's missing a couple of cylinders
Post #615802 Thu Jul 15 2021 11:05pm
eddyeggs
Ok thank you, hopefully someone will jump in and let us know, take care
Post #615805 Thu Jul 15 2021 11:13pm
knwatkins
Body can be lifted with jacks Thumbs Up Kev
Post #615823 Fri Jul 16 2021 2:31pm
iforland
Did the job last weekend on the drive, used 2 bottle jacks to lift body (had to place them on some railway sleepers because I had the car up in the air on axle stands....
One thing to note is that the guide I was using did not mention that you need to disconnect the little rear dampers between chassis and body (right by tail pipes and the large swinging lump of steel)...without that the whole thing started to lift!!
Also be careful where you place the jacks.
A pig of a job, mainly because the torq bolts that fix the pipes to the roll bar would not come off, thank goodness for my dremel. Removed propshaft to improve access.
Post #615834 Fri Jul 16 2021 6:25pm
eddyeggs
Guys thank you so much for your advice, at least I know it can be done without the whole shell being lifted at £2000
Post #615836 Fri Jul 16 2021 8:04pm
eddyeggs
Hi sorry you mentioned a guide are you able to share that in any way, also what was the best price for the anti roll bar
Post #615837 Fri Jul 16 2021 8:15pm
