Home > General (L494) > Anyone Fitted the Auxiliary Belt Tensioner and a New Belt - |
2 RRS Member Since: 04 Sep 2016 Location: Stafford/Telford Posts: 112 |
Easy job if the vehicle is not a dynamic model, if it is then the ARC pump needs to be dropped off it's mounting to pass the belt around it. 20 mins for std vehicle, double that for dynamic. |
Tue Jun 22 2021 9:06am |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 578 |
Thanks , Its a Dynamic |
Tue Jun 22 2021 9:15pm |
Whats involved in fitting just the tensioner ? |
Fri Jun 25 2021 8:08pm |
5 minute job. release the belt with a 3/8 ratchet extension/bar and then a 15mm bolt holds the tensioner in place. My belt has done 204K and is still fine so I'd imagine you just need to change the tensioner (mine went noisy about 10K ago). Are you sure it's the tensioner that's noisy and not the alternator? Maybe stick a bar against the alternator and tensioner and have a listen. |
Fri Jun 25 2021 8:35pm |
Tensioner fitted earlier and guess what , you were spot on
Sat Jun 26 2021 8:13pm |
Thought it might have been.... Not too bad a job, all from engine bay, remove belt and tensioner (gives you a bit more room), 3 bolts hold the alternator (2 towards the front and one at the rear, pull it forward and by touchy feel undo the main 12v battery feed cable and one clip in cable at the rear of the alternator. Obviously make sure you disconnect main battery in boot first, otherwise you'll have a firework show on your hands! Prob 60-90 mins first time doing one.
Sat Jun 26 2021 8:29pm |
Thanks a lot for your help its much appreciated |
Sat Jun 26 2021 9:05pm |
Thanks it appears two are listed for it , Can anyone help with the OE number for the alternator - 2014 hse dynamic 3.0 dsl |
Tue Jun 29 2021 10:08pm |
LR part No. is LR088850 (recon, outright), part No. on unit is CPLA-10300-BD
Wed Jun 30 2021 12:40pm |
Brilliant thanks again for your help
Thu Jul 01 2021 1:21am |
Result! |
Fri Jul 02 2021 9:43am |
Moved the car over on the driveway when I got back home tonight , ready to fit the alternator tomorrow and its showing suspension fault and adaptive dynamics fault on the dashboard
Fri Jul 02 2021 9:14pm |
Maybe low battery if the aux belt is removed? I'd sort the alternator and then take another look. |
Sat Jul 03 2021 3:16pm |
Alternator fitted and fine
Sat Jul 03 2021 5:10pm |
