Home > General (L494) > MY17 SDV6 Crankshaft issue? |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Really! how many cranks have failed vs how many V6s out there? its hardly a common issue. its just the ones that are a problem get reported online - usually people just sign up to report it then they vanish. Sure its a concern but the chances of it happening are low, Just get a good warranty that covers it, Why would'nt you have a warranty on a RR anyway? If you look at other marques you will find just as scary issues that are .... "common online" ....... I have read almost every forum that has this point reported, although not thorough or proved it seems to be cars that have done a lot of short runs / diluted / aged oil / low oil level on most failures. These engines use oil and if the level isn't maintained with good correct grade oil then what do you expect. if mine fails then its bad luck and ill eat my hat but I love the car and the engine is very good. my warranty company have given me in writing that I am covered so ill enjoy the car. ok mine is a L320 but the same principle.
Wed Jun 23 2021 9:55am |
TimD Member Since: 21 Jun 2021 Location: Leeds Posts: 7 |
I think it's more that if the crankshaft goes (and there's literally no way of knowing if it will or not - no matter how well serviced), the result is catastrophic and needing a new engine - at a massive cost.
Wed Jun 23 2021 10:04am |
I can PM you the company but I have heard of a few companies paying out, When taking out the policy ( i used them for a few years on previous cars) I specifically asked if the Crank / bearing issue on this engine is covered and I have confirmation that it is before buying the car.
Wed Jun 23 2021 10:59am |
Yeah, PM the company - that would be great. (an if you can, the rough cost)
Wed Jun 23 2021 11:14am |
But if the crank fails it is a sudden failure.
Wed Jun 23 2021 11:21am |
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 |
Bad enough for me to significantly up my budget so that I didn't have a car with it. Utterly intolerable after living with BMW's iDrive for several years. Ferrari F430 Spider F1 MY17 RRS AB V6 2CV6 Special |
Wed Jun 23 2021 9:24pm |
Chips Member Since: 09 Nov 2017 Location: Shropshire Posts: 101 |
Yes I got out of a MY16 into an MY18 just to get rid of the sat nav , new one much better , not to Audi level that I had previously but good enough . Unfortunately despite living rurally in steep hills and doing over 20k miles per year with full LSH the MY18 snapped a crank ! It's just pot luck and nothing to do with servicing or driving style . Our My 16 suffered oil dilution which the MY18 doesn't but it's crank was fine MY 18 RRS HSE Dynamic ,MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in ! |
Thu Jun 24 2021 9:09am |
AnotherMutley Member Since: 06 Mar 2018 Location: South East Posts: 16 |
If you look at QP Online, I think the crank issue is wildly under reported. I've run 2 V6 cars and put big mileages on both, would I buy another...no. Get the V8 and have done with it, apart from coolant leaks when they get older, they seem a stronger engine. You can shop around and get warranties but its only when you claim that you find out how good they are. Some people have had great success with the JLR Approved Used Warranty, others not. |
Thu Jun 24 2021 5:50pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8872 |
Do people really use the in-car sat nav? Google maps on the phone set at the base of the A-pillar where it's easily visible and out of the way. Much better than in-car systems and no need to worry about updating the in-car system. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jun 24 2021 8:29pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 400 |
Mine Has the old tech been a 2015 model but I haven’t really got a problem with it. It’s a lot better/quicker than my 2012 RRS tech |
Thu Jun 24 2021 10:54pm |
The issue I have with in car systems is the need to laboriously input the destination. It's bad enough if there's just one, but if doing a route with a number of stops, it takes several minutes with LR's glacial system (the newest one might be quicker, don't know).
Fri Jun 25 2021 10:30am |
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 |
I can do this with my 2018 RRS nav? You can plan a route on your PC or phone and then it's ready to go when you get in the car. |
Fri Jun 25 2021 10:33am |
Well, yes. Have no particular issue with it and can't be arsed with using my iPhone. Ferrari F430 Spider F1 MY17 RRS AB V6 2CV6 Special |
Fri Jun 25 2021 9:07pm |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 97 |
Apple CarPlay is excellent on the later models and I purposely sought out a vehicle which had it. The Incontrol sat nav is ok, but it’s not really currect unless you’re paying for updates whereas CarPlay is free and better. |
Wed Jun 30 2021 9:44pm |
