Home > Wheels & Tyres > Off-road tires 2013 rrs |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Being a petrol V8 17" or 18" wheels will not fit your vehicle - will not fit over the brakes. Not sure if 19s will fit. 07MY RRS TDV6
Fri Mar 05 2021 5:08am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
I think you need to be a little more specific with your vehicle model if it's a 2013 RRS1 it will not be a 4.4L petrol or diesel as they did not produce one, they dropped the 4.4 petrol around 2006/7 and never fitted the 4.4 diesel to the RRS1. If it's a 5.0L petrol it will have 6 pot brembo's which will certainly limit your wheel options, if it's a 2013 L494 it will be the 4.4 SDV8 diesel or 5.0L petrol and not sure what brake calipers the SDV8 had fitted from the factory. Not sure but have a vague re-collection there was a post that someone had fitted a specific style 19" rims over the 6 pot's.
Fri Mar 05 2021 7:23am |
Manningwb Member Since: 05 Mar 2021 Location: Colorado Posts: 8 |
I’m in USA. It’s a 5L V8 petrol |
Fri Mar 05 2021 4:36pm |
I don't believe it has the Brembo brakes... I think those were only on the Super charged version for 2013. |
Fri Mar 05 2021 4:56pm |
Easy enough to tell, just post a close up picture of front wheel.
Sat Mar 06 2021 12:17am |
Not sure of the Brembos but all V8s have bigger brakes of one sort or another so 17" and 18" and maybe 19" will not fit. 07MY RRS TDV6
Sat Mar 06 2021 1:09am |
L/R actualy list this 19" rim as "off road alloy wheel" style 1 (LR017276) which fit all 2010-2013 from SE through to 5.0L S/C A/B originally as a no cost option, so if their sales brochure is correct there is a 19" wheel that will fit over any of the brakes, brembo or other wise. Also thought the Compmotive PD 1881's 18" rims also fitted vehicles with the 4 pot brembos on the TDV8 as well but not the 6 pot's, not the cheapest of rims though.
Sat Mar 06 2021 1:59am |
Sat Mar 06 2021 9:04am |
Thanks for that. Mine does not have brembo brakes so those options will all work on my truck. If anyone else has any other suggestions, feel free to share! |
Sun Mar 07 2021 1:25am |
Sun Mar 07 2021 3:06pm |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Like those Evo Corse for shooting in the winter if they go over the six pot Brembos There is no replacement for displacement - W O Bentley MY2013 5.0 Supercharged HSE L320 |
Sun Mar 07 2021 4:30pm |
Since we are on the topic. Now comes tire selection. One tire I really like is the AMP All Terrain Pro, only issue is they come is 3 sizes for 18”. The only one that would remotely fit would be 275/65/18... I have a 2” lift. Does anyone know how this would fit? I assume it would but will I need to do some hot gun fender molding or relocate any components? |
Mon Mar 08 2021 4:59am |
What tire size are you running? I’m looking at 285/65/18 but a little worried about the extra width and rubbing? I’m happy to do a little fender molding but also happy with less modifications. Thoughts? Thanks again for the recommendation... I think I’m going with the 18” compomotive wheels; I like the simple look. Last edited by Manningwb on Tue Mar 09 2021 12:02am. Edited 1 time in total |
Mon Mar 08 2021 5:12am |
I run a 265/65/18, i dont run any lift although i can if i wish as i have a LR Passion electronic easy lift controller. No rubbing at standard height, still clears using access height and with all air gone and on the bump stops although I wouldn’t drive in these modes!
Mon Mar 08 2021 8:23am |
