Home > Maintenance & Modifications > TDV8 Oil Change |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
It's probably an oil temperature sensor
Mon Feb 08 2021 3:34pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 390 |
I have added no oil since and driven about 50km. The oil dip stick still shows the sump is full. But 2l less than the specified oil fill is a bit unnevering. |
Mon Feb 08 2021 3:51pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Sensor next to the horizontal drain plug is the oil temperature sensor. 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 08 2021 5:21pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Apart from the car not being level when the sump is drained the only thing that springs to mind is did you change the filter first as per the w/shop manual, before draining the sump?
Tue Feb 09 2021 4:33pm |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 |
That is quite strange - the LR dealers over here perform a topside change and that’s what I did. Wasn’t too keen on rolling on the floor and pulling off all the skid plates underneath just to get to the drain plug, and the filter is also topside - on your next oil change I highly recommend it. Also you mention a dipstick - don’t have one on my 2012, it’s electronically calculated and displayed on the dash. But if yours shows full, should be all good.
Tue Feb 09 2021 6:34pm |
Kev1bikes Member Since: 27 Feb 2021 Location: Staffordshire Posts: 4 |
Changed Oil / Filter in my TDV8 I also only put about 7 litres in and Looks High on dip stick.
Sat Feb 27 2021 8:21pm |
