Home > General (L494) > L494, Main battery Replacement instructions |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 395 |
Hi all this is just a standalone post for the repalcing of the main battery on an L494 Range Rover Sport (so it might be easier to find futher down the line and from google
Thu Dec 17 2020 3:24pm |
Hi Mate I think as yours is 2017 the backend software system changed so it might be that the GAP tool only has limited functions on I think it went up to 2016 which might explain there isnt much you can see on the menu.
Tue Jan 19 2021 12:37pm |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 |
Hi, PJ another good post cheers. I’ve got the capacitor in my car as I only just discovered yesterday. I’ve just ordered the same big battery as you’ve got. Is that still correct do you know? Just had a thought there so thought I’d ask 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Mon Jan 25 2021 10:57pm |
HI Mate yep it should be the main battery doesnt seem to have changed much since the RRS2 appeared, and when you look about at the normal places to buy them the same ones appear regardless of age so I think you are pretty safe.
Mon Jan 25 2021 11:09pm |
Thanks for your help PJ 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Wed Jan 27 2021 10:46am |
So battery changed tonight, no issues at all just had to reset the date and time. Took the car out for a drive for around 15 mins. Still no start/stop function. Well I don’t think so any way. However everything else is running smoothly and no struggle at all to start, no flickering lights....nothing. Thanks PJ great post 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Wed Jan 27 2021 11:41pm |
ASS only works when it thinks it can adn the engine is warm enough, so if in 15mins the car might not have got warm enough for it to kick in, if you had heated seats and AC on full and maybe heated steering, lights then it doesnt always come on as all those features take their toll on the battery so ASS doesnt kick in. Also if it hovering around 0 that can also stop it from working.
Thu Jan 28 2021 11:46am |
Thanks for the info...I will keep an eye on it. I’ve gone this long without it ever kicking in so I’m not to worried. Would be nice to know the function does work though. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Thu Jan 28 2021 12:19pm |
Three-Six Charlie Member Since: 21 Mar 2019 Location: Wigan Posts: 60 |
It's possible to avoid having to reset anything if you leave the engine running whilst you change the battery. An auto-electrician I know gave me that hint before I swapped mine over two years ago. Worked a treat, but I was very careful to insulate both battery leads after disconnection and minimise the time between getting the old one disconnected and the new one connected. 2013 L494 5.0 SC in Chile Red |
Thu Jan 28 2021 10:45pm |
Soooo the ASS kicked in today for the first time since owning the car haha. Must of needed a new battery for nearly 2 years, I’ve also noticed that the dials on the dash show them selves a lot quicker and my memory seats do a full cycle when changing between drivers. I’ve often had to press the number two or three times. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Fri Jan 29 2021 7:30pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 260 |
Possibly the reset when the battery was changed, rebooted the system and fixed those issues.
Fri Jan 29 2021 7:44pm |
I think your probably right as all the electrical functions seem a lot more responsive. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Sat Jan 30 2021 9:49am |
Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 26 |
Will this battery work aswell mate? The EK900 one was out of stock for a while but now the think you provided takes you to a EK950 |
Fri Feb 19 2021 10:33am |
Yep mine is the EK950 I would guess that its the replacement for the EK900 that isnt being made anymore.
Fri Feb 19 2021 11:10am |
