Home > General (L494) > Engine oil leak SDV8 |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
My money is on the oil cooler on a 4.4 tdv8 Visitor from fullfatrr.com
Thu Dec 17 2020 5:41pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 864 |
Checking today I can't see oil on top of the engine although I would need to remove intake to get a good look. Oil is dispersed at the rear of the sump guard. Where is the oil cooler located ?
Thu Dec 17 2020 9:47pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4866 |
Not the best pictures in the world but first one shows oil filter/cooler assembly under the intake manifold plenum chamber, second picture shows it exposed if there of any help.
Thu Dec 17 2020 10:16pm |
Thanks for the dia, When I took the cover off I could not see oil, but will use a bore scope and see , may have to remove intake.
Thu Dec 17 2020 10:25pm |
Head over to the sister Full Fat forum as the 4.4 TDV8 was first used in them from 2011
Fri Dec 18 2020 9:08am |
OK pulled the sump guard off, what an exercise that was , be warned the once only use bolt and washer system is overkill and you may end up needing a grinder.
Sat Dec 19 2020 7:25am |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 |
Hi.
Tue Mar 16 2021 8:25am |
The answer is above, two new o rings and a new gasket is the fix. Cost me 350 pounds. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Wed Mar 17 2021 12:45am |
Hi Irbails.
Wed Mar 17 2021 8:05am |
