Home > In Car Electronics > No reversing camera or parking sensors |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4871 |
They are not cheap these day's but the Gap Diag. tool is worth it's weight in gold if you intended to keep the vehicle some time, only need a few visits to a dealer just to have codes read and paid for itself, always a good second hand market for them as well. I believe you can purchase a new licence for it relatively cheaply if you change to a different L/R vehicle.
Thu Oct 29 2020 10:53pm |
This is the one most guy's on the forum go for I believe, the BT version, you might need to shop around a bit as they do vary in price a little, it really isn't difficult to use, but that is easy to say if you know how to use it, there is a quite comprehensive user manual goes with it, their customer service is second to none in my experience and Patrick at Gap is extremely helpful if you have a problem. If you wanted to PM me a e-mail address and I could send you a PDF of the manual if you wanted to have a look first.
Thu Oct 29 2020 11:08pm |
You don’t have a IPM B so that shouldn’t be applicable. Just check under the passenger seat for a silver box. It shouldn’t be there but if it is, there’s a bigger issue at play. I’ve got a feeling that these may be separate faults here but maybe attributed to one common occurrence. Heavy rain, power surge or something like that. The only interaction these systems have is over the CAN and at the head unit for display. Normally tapping the reverse camera image will switch it to the graphic for parking aid display. What I don’t understand is why they won’t activate automatically or manually which is why I’m thinking it’s either separate faults with a common cause or a CAN BUS fault for the switching. I don’t know any reason for a corrupted video image on the screen other than a camera and that has zero to do with the parking aid. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Oct 30 2020 11:35am |
As I said not a auto electrician and may have read the diagrams wrong, but this appears to be a common earth point between the rear view camera front parking sensors and the dash switch, so may be worth having a look at, although as I said could be way off base.
Fri Oct 30 2020 9:41pm |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Hi Col! This looks like a good starting point. Base of the D pillar - is this the one behind the nearside rear light cluster that was mentioned in another thread in 2017?
Fri Oct 30 2020 11:09pm |
Agh yes, good spot, C2924T is the ring termination for the camera and C2922T is the ring termination for the parking aid module, all on the same earth post.
Sat Oct 31 2020 1:30am |
Just realised, mis-read terminal number C2568T thought that was the earth connection for the dash switches as well, but I see that is C2598 and is at bottom of R/H "B" post.
Sat Oct 31 2020 1:59am |
Update - sensors and camera still not fixed due to the specialist at Loughrans being off for a few weeks. Oddly, started the car tonight and whilst in park the camera suddenly sparked into life - with parking lines, etc. Very odd. Only did it the once but at least I know the camera itself is not completely dead There is no replacement for displacement - W O Bentley
Thu Dec 17 2020 10:00pm |
Had you been in the boot?
Fri Dec 18 2020 12:38pm |
Last night it worked after I had just been in the boot so definitely worth a try. Thanks Brit! There is no replacement for displacement - W O Bentley
Fri Dec 18 2020 1:55pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
so ours had a bit of a fit a little while back after some heavy rain
Fri Dec 18 2020 5:25pm |
UPDATE - Finally made it to a garage today and had the problem fixed. As always the forum gurus were right It was the front off side parking sensor. Everything now works again - including the parking camera.
Mon Mar 22 2021 6:12pm |
How ridiculous is that, it’s got to be a software driven issue for the reverse camera to not work because of a front sensor failure. After all, you can have rear sensors only with a camera! 2012 5.0 SC AB
Mon Mar 22 2021 6:20pm |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 36 |
I’ve the same problem. I think it’s a bad rear parking sensor and have one ordered.
Wed Feb 15 2023 11:38pm |
