Home > General > Upper tailgate corrosion |
Topcat2308 Member Since: 24 Nov 2016 Location: Merseyside Posts: 14 |
Fri Oct 16 2020 8:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4867 |
You can actualy buy both those panels new from L/R around £150.00 the pair.
Fri Oct 16 2020 9:43pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4808 |
The tailgate is aluminium so you may struggle to weld to that.
Sat Oct 17 2020 6:33am |
L/R don't list new studs unfortunately, not knowing how deep the lugs are or how many there are bonded to the glass, but is there enough depth in them to possibly drill and tap a short thread in them so you could screw a piece of threaded rod into to form new studs.
Sat Oct 17 2020 6:43am |
I am hoping that the blocks that are bonded to the glass are metal, as opposed to ally. Hopefully I can either remove/ drill out the remainder of the studs and either re-tap using a threaded rod or tack a stud to the block. Either way once I remove the knackered bar there is no going back. If neither solution works looks like a replacement tailgate. If this is the case it will be getting a heavy dose of sealant and wax oil.
Sat Oct 17 2020 5:46pm |
