Home > Technical > Snapped Crankshafts? |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 |
I've just scared myself silly and read about snapped crankshafts on RRS's and was wondering how much of a problem this is and which models are the most affected?
Thu Aug 13 2020 12:37pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1151 |
No prevention, and no way of predicting if/when it will happen.
Thu Aug 13 2020 1:18pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
If I remember reading something on this forum correctly, I recall that the problem is in the design of the big end bearings. In the good old days when I used to rebuild my MGB engine, you had big end shells with a little tab which located in a recess in the crankshaft. Once located and bolted up, there was no way that the shells could move. This meant that the oil ways all lined up.
Sat Aug 15 2020 8:38am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
No, your not dreaming it Robin. Lots of people think that.
Sat Aug 15 2020 9:03am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
dumb question but when they occur is the entire engine just destroyed? i mean is a rebuild completely out of the question if i managed to buy the car at rock bottom prices? |
Thu Aug 20 2020 10:45am |
I know it is off topic as I'm straying into MG territory, but I can't understand how the shells could move in the bearing with a tab - unless they break off, of course. Once tightened up, they can't move. My MG engine was built before 1967 and still works. Sounds to me like LR have designed out a perfectly serviceable and functioning part for no apparent reason.
Thu Aug 20 2020 11:32am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4881 |
I thought for some reason that was part of the problem, someone in their infinite wisdom decided the shells/rods didn't need the locating tabs anymore.
Thu Aug 20 2020 11:57am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4352 |
In all of the 3.0 engine failures I've seen through our doors, every single one, without exception has been low on oil at time of failure... |
Thu Aug 20 2020 1:54pm |
No, rebuilds are possible. If the bearing has turned, the chances are that the block is still good and the crank can take a regrind. If the crank has given way, the chances are that the block would have warped and a rebuild will cost a lot more because you will need to find a good block. Here's my post when it happened to me... https://www.disco3.co.uk/forum/oval-autos-...80253.html Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Thu Aug 20 2020 2:31pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4817 |
What do you call low mike ? Below min? |
Thu Aug 20 2020 7:20pm |
Sub 3L...
Thu Aug 20 2020 7:41pm |
Humm. That is low. |
Thu Aug 20 2020 8:35pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
I wonder if folks don’t check oil levels like we used to years ago Visitor from fullfatrr.com
Thu Aug 20 2020 9:11pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8877 |
The emissions friendly electronic dipsticks don't help. You need the engine to be "just so" where an old dipstick you could wander out and check it any time you liked.
Thu Aug 20 2020 10:20pm |
