Home > Technical > Limited gears |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8875 |
Download tbe workshop manual. It has the process for gearbox removal. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 12 2020 12:25am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Ok thanks guys.
Wed Aug 12 2020 8:02am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4817 |
well it can't be in Park as you need to rotate the flywheel to undo the bolts thru the starter hole.
Wed Aug 12 2020 10:30am |
Ok thanks Andy makes sense, just like to get these small details sorted out before I start
Wed Aug 12 2020 11:49am |
I can't remember if the electronics (inside the gearbox) is paired to the car.
Wed Aug 12 2020 12:00pm |
When I leave in neutral I cannot remove the key from ignition, not saying that's an issue as I'll be disconnecting the batterry, but that's ok , correct ?
Wed Aug 12 2020 12:11pm |
Yeah that is correct.
Wed Aug 12 2020 12:26pm |
Watch at 5 mins and 14 mins.
Wed Aug 12 2020 12:33pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4352 |
The engine will turn with the gearbox in Park... |
Wed Aug 12 2020 12:45pm |
The important thing on the diesels is to remember to unbolt the exhaust cross over pipe bracket.
Wed Aug 12 2020 1:04pm |
Stuck at trying to get the bolts out of the front section of the front prop shaft. Thought I could turn this by hand but it's like it's stuck in a gear. Otherwise seems impossible to get to the two remaining bolts at the top of propshaft. Any ideas ?
Wed Aug 12 2020 5:46pm |
Started already thought that vid had put u off.
Wed Aug 12 2020 6:09pm |
Yes neck deep now, no turning back
Wed Aug 12 2020 7:30pm |
No. You must lift one wheel |
Wed Aug 12 2020 7:41pm |
