Home > General > Dreaded 'Restricted Performance' |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
I'd get yourself your own diag tool to save hassle. Could it be egr valve? Also I'd check for misfires, sometimes they set the reduced performance off but no codes. Also what diag tool are they using? |
Tue Aug 11 2020 1:50pm |
willster174 Member Since: 11 Mar 2020 Location: Peterborough Posts: 12 |
Hi
Tue Aug 11 2020 2:08pm |
So if you wanna splash out there's the gap iid tool, it's the best one aside from actual dealer software. But it costs around £400. I purchased just a crappy £20 dongle of amazon at first. It showed enough.
Tue Aug 11 2020 2:20pm |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 |
Just had my inlet manifold done and my cheap code reader didn't pull up the fault. The garage had to look into historic codes to find it. Mine wouldn't let me check those |
Tue Aug 11 2020 4:17pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Worth checking the MAP sensor's
Wed Aug 12 2020 10:34am |
