Home > Technical > Does my RRS have the variable dampening system? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Is there a dynamic mode on the terrain response button (looks like a twisty road)? If yes, then it has variable dampers. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 07 2020 8:41pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
I thought the dampers were not variable but the dynamic response system provided variable roll bar effect. 07MY RRS TDV6
Sat Aug 08 2020 1:50am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4864 |
Build spec. on my 5.0L S/C say Continuous Variable Damping which I believe was standard on the S/C not sure about other models though, actualy has label on the damper its's self saying CVD.
Sat Aug 08 2020 2:28am |
In the facelift they went to variable dampers as well as the hydraulic anti roll bar. Which is great on road but not on the pocket as the dampers are >twice the price. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Aug 08 2020 9:42am |
Oh Ok - I have had my car for 10 years and never felt the need for either. 07MY RRS TDV6
Sat Aug 08 2020 10:38am |
rjbrocklesby Member Since: 04 Nov 2017 Location: Lincolnshire Posts: 25 |
It does have the dynamic "twisty road" setting and is the face lift version (the one with the round shift selector that raises on starting.).
Sat Aug 08 2020 10:46am |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
I’d wait till it’s diagnosed before you wish that Joined the X5 45e club
Sat Aug 08 2020 11:08am |
You can't miss what you haven't had. Having had the hydraulic ARB on both of my RRS, I must say I like it. Never driven an RRS without it but have driven Disco without it and it was noticeable on twisty roads. The variable damping is noticeable in dynamic mode but I could live without it having not had it on my previous RRS. What I'm not keen on is the silly round gearbox selector on the facelift. Much preferred the stick on my old one. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Aug 08 2020 11:46am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
As above, I love my hydraulic ARBs. It keeps the vehicle nice and level when cornering at speed. It also allows the ARBs to be decoupled when off road for better wheel articulation.
Sat Aug 08 2020 2:10pm |
My mechanic reckons it's the pump cos of the error code. It does run, sounds noisy to me, not sure if that's normal?
Sat Aug 08 2020 4:00pm |
What issue are you having and what is the error code? Kev
Sat Aug 08 2020 4:40pm |
If started with the ride height only warning intermittent,happened maybe three times over a couple of weeks, then went to suspension failure on Friday.
Sat Aug 08 2020 5:14pm |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
Sorry to resurrect an old thread but I am being asked the same question by the guys at GAP as I have an issue with my Ride Level Module.
Tue Oct 19 2021 9:31am |
If I remember correctly have a look at the top of the front or rear damper under the wheel arch, if you see a electrical wire coming out of the damper you have it if no wire you don't.
Tue Oct 19 2021 9:48am |
