Home > Technical > parking brake fault after fully closing |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4820 |
I think you need to explain More |
Fri Jul 03 2020 7:12pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
so i swapped out one sides brakes shoes and discs.
Fri Jul 03 2020 7:16pm |
You only need to have 1 wheel up.
Fri Jul 03 2020 8:05pm |
You may have to do this
Fri Jul 03 2020 8:12pm |
Ahh perfect, I also have gap iid tool which has its own unjam procedure so fingers crossed there |
Fri Jul 03 2020 8:21pm |
All sorted ta. What happened was the parking brake cable slipped out of the enclosure cause I did it wrong so the cable is fully shut hence the noise from the motor. I just need to replace on of my wear sensor cause I broke it and slam dunk.
Sat Jul 04 2020 4:38pm |
Forgot the choc was there? |
Sat Jul 04 2020 6:21pm |
yeah i drove forward and slightly bent the choc wear sensors done as well. squealing hasnt gone though. it is much better |
Sat Jul 04 2020 6:33pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I've driven over my chocs a few times . I think I need to make a sign to hang on the steering wheel reminding me they are there! Robin
Sun Jul 05 2020 8:03am |
put it on the back of the "on charge" sign ! |
Sun Jul 05 2020 10:48am |
