Home > General > Where to buy tow electrics for late 2012 sport.
Smarttech
Need the towing electrics for my Sep 2012 sport but it's a bit confusing as to what I need as I sure 2012 is different from 2011 but looking online the list 09-13 for some looms 2012-11 for others but not finding anything that confirms 2012 compatible .
Anyone suggest where I can purchase from that is good quality and with everything needed. 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #567206 Wed Oct 17 2018 9:15pm
The part number for the L/R kit for a MY12 on is VPLST0071 for the 13pin plug and VPLST0070 for the N&S 7pin plug. You should be able to cross reference to a pattern part I would think. I did manage to pick up a new genuine L/R 13 pin kit off ebay for £60.00 but that was just luck I think. A member on here 215m3 just recently bought the wrong one for his car, he might have what you need unless he managed to return it. Have a look at the link below, I have added a pdf file of the fitting instruction for 0071 kit to my gallery if you wanted a quick look, should be able to download from there as well if you wished to I think.
http://www.rrsport.co.uk/forum/topic52239.html
Post #567208 Wed Oct 17 2018 10:29pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I bought from here and they were spot on for a 2012 SDV6 pre-new shape
https://www.pfjones.co.uk/towbar-wiring-ki...-kits.html
Post #567221 Thu Oct 18 2018 9:57am
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Agree with PF Jones as the system is plug and go!
Post #567239 Thu Oct 18 2018 4:32pm
Brit Plumber
You’ll probably need or at least want to have the files updated. That will stop the parking sensors beeping when the trailers on and you’re in reverse and I think it also alters the suspension. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #567246 Thu Oct 18 2018 7:35pm
Smarttech
Do you need to go back to Land Rover for the software update to tell it you have a tow bar ? 2017 SVR. SVO Scafell grey Ebony interior
Post #567248 Thu Oct 18 2018 9:53pm
If you have the IID tool you can do it yourself or any good indi. could do it for you.
Post #567249 Thu Oct 18 2018 9:59pm
215m3
Yes a nightmare. I managed to send the part back as was from Rimmer Bros. I purchased a part from LR from ebay at a discount/cost. Yet to fit it, but I know what to do as had it apart 3 times now.
I got mine from Beadles Sidcup LR, maybe give them a call as they checked against my vin before sending. The plugs look correct and there is also a wire for the soft close boot I was concerned about.
Goodluck with it 2010 3.0 TDV6 RRS Overfinch GTS
1987 BMW E30 M3 2.4 Turbo
1990 BMW E34 M5 3.6 Trackcar
Post #567270 Fri Oct 19 2018 1:52pm
Smarttech
Ordered my dedicated loom tow electric's from PF Jones this morning on the phone as it was quit confusing as to which was the correct loom when looking on website.
Should be with me on Monday. 2017 SVR. SVO Scafell grey Ebony interior
Post #567298 Sat Oct 20 2018 12:55am
Brit Plumber
It shouldn’t be confusing.
If it’s a 13 pin you want it should be 29190512PF for a PFJ manufactured item at £74.55 or LR02013U for an ECS manufactured item at £110.88 they are the only 13 pin available. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #567300 Sat Oct 20 2018 8:30am
Smarttech
Electric's all fitted once I had the bumper apron off as couldn't get my hand up between the chassis and the bumper to reach plugs. Only took about a hour and a half in the dark working with a torch.
Just need to get it plugged in to tell it the tow bar is fitted and job done. 2017 SVR. SVO Scafell grey Ebony interior
Post #567497 Tue Oct 23 2018 7:29am
G REG
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
RRS 2005
Already have quick fit ball but need standard 7 pin electrics fitted. Prices seem to vary massively, can anyone recommend fitting service in SE London/Kent area please?
Post #600367 Wed Jun 17 2020 10:37am
sportgoogle
Bearmach.com
Offer a range of 7 or 13 pin kits, also other parts for chassis, engine etc RRS HSE SDV6 2012
Post #600368 Wed Jun 17 2020 11:01am
https://www.rrsport.co.uk/forum/topic5581.html
Post #600370 Wed Jun 17 2020 12:11pm
Duc750
it should "work" without but will not silence parking sensors or turn off the fog lights 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #600441 Thu Jun 18 2020 4:03pm
