Home > Maintenance & Modifications > ace pipe leak |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
it is indeed, am glad, this is one of those things I didn't wanna lift the body for because it is parked on the side of the road haha |
Sun May 10 2020 10:46am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4346 |
In all fairness, I do them on the floor. Saves a lot of hassle |
Sun May 10 2020 11:34am |
I’ve used a similar stuff (it maybe the same stuff without the brand name) but it doesn’t appear to work for long on the exposed areas, I think the hostile environment under the car just means nothing can stop the onset of corrosion other than regular preventative maintenance. The ACF is designed for aircraft and sounds like it’s good stuff, but an in service aircraft is checked all over on a Before Flight, After Flight and Turn Round servicing. Corrosion and damage is picked up and dealt with in a planned manner. How often to we actually go under a car, clean it, inspect it and address corrosion. The average person probably never sees the underside of a their car. I oil the exposed underside where I can but I think it’s just in my head and probably won’t make any difference in the long run 2012 5.0 SC AB
Sun May 10 2020 12:22pm |
i used it before on my motorcycles when I used to ride the winters. to its credit applied every 3 month it kept them rust free. so i may do something similar. around winter time |
Sun May 10 2020 12:38pm |
right i've managed to secure a drive for for this saturday haha. lets say I take the pipes off and the valve block the bed. will the car be driveable as long as i don't take the on the cornering and I plug the ace reservoir and sway bars incase I need to get it home? |
Thu May 14 2020 8:41am |
The ACE pump is running all the time as it runs off an Aux belt. You will likely knacker the pump by running it dry. You could maybe somehow connect the feed and return together so it feeds in a loop but it does operate at upto 300bar (I think that’s right). Pray those pipes come out.
Thu May 14 2020 11:20am |
ill do that. i was just going to cut the old pipes tbh front and back and remove the valve block then work on it from there |
Thu May 14 2020 11:35am |
Yeah you could do that but give yourself plenty of pipe length on the block for you to grasp hold of. 2012 5.0 SC AB
Thu May 14 2020 12:07pm |
Looking at the new pipes. It seems the entire old block pipe holder comes out and the new ones slots in? |
Thu May 14 2020 1:08pm |
Yes that’s right, the whole plate/holder is replaced. If I remember correctly, the plate holds the plastic seals over the flared parts of the pipe. I originally saved those seals just in case but I soon binned them when I didn’t have any leeks. 2012 5.0 SC AB
Thu May 14 2020 2:07pm |
I guess we'll see how it all goes. the valve block, is it held with screws from underneath or is that some on top? |
Thu May 14 2020 2:45pm |
Guess what I've got on tomorrow
Thu May 14 2020 3:53pm |
haha did your pipes go again? |
Thu May 14 2020 4:52pm |
Customers car
Thu May 14 2020 5:00pm |
