Home > General > New engine ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
can you not just get the gaskets changed ? |
Fri Apr 10 2020 4:33pm |
dashingdave Member Since: 20 Sep 2014 Location: Dogtown Posts: 29 |
...yes might do that as a best price option. It keeps blowing off the top hose where it connects to the block. A really awkward clip to access. Also thinking to try an expensive radweld treatment, leaving the header tank screw cap loose to alleviate pressure. Then see if I can get another 12 months out of it . It's on the cusp of not being salvageable. Still I've always indulged it so no expense spared to keep it running. Many many new parts. If someone offered me £2750 I'd take it.Goes really well, uses no oil and ok on fuel. Nothing not to like. |
Fri Apr 10 2020 9:57pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
I don't think the engines are available as parts so basically you'll have to buy a whole new engine from Land Rover. And that'll be well over 10 grand. Probably nearer 15 grand.
Fri Apr 10 2020 10:42pm |
Don’t add radweld.
Sat Apr 11 2020 10:29am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Can you not buy a new short engine with the TDV8 like you can with the TDV6 for about £4.5k + VAT? That'll save buying a whole new long engine. But yes, I agree buying just a block is probably unlikely, if it really requires this. As Andy mentioned, I'm not sure why a new gasket will not resolve the problem along with a head skim if needed. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Sat Apr 11 2020 12:43pm |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
When I offered my perfect 3.0 SDV6 MY12 engine for sale with 33k miles at £2,500 there were no takers. That was 6 months ago! RRS (MY13) Santorini Black SDV6 HSE luxuary
Sat Apr 11 2020 4:16pm |
Wow, that's really surprising. I thought the TDV6 engines were in high demand. Kev
Sat Apr 11 2020 4:18pm |
Hmmm, I think we're dealing with a dinosaur club here. Magnificent machines but just had their day. There doesn't seem to be any pressure in the hoses so not sure why it's blowing the hose off. Good idea to loosen the cap. I'll experiment with some gunk and risk it clogging the system. The technology seems to has improved on sludge front and I'll remove the anti freeze first to stop any reaction. If lucky it should work. I'm often told these engines are bomb proof. Keep you posted. |
Sun Apr 12 2020 8:58am |
Don't fill it with gunk. Just change the head gasket. 2012 SDV6 - it's missing a couple of cylinders
Sun Apr 12 2020 9:54am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
Have you had a "sniff test" carried out on the cooling system to see if combustion gases are getting into the cooling system.
Sun Apr 12 2020 10:12am |
The easiest way to do this is to fill the coolant right up to brim, run the engine, give it a rev and if you see bubbles in the coolant, this is a tell tale sign. Kev
Sun Apr 12 2020 10:15am |
Not sure if they can jam in anyway but might be worth £5.00 or so for new header tank cap, start with a few cheap things first.
Sun Apr 12 2020 10:35am |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
It has a value as it is, but with any stop leak added this reduces it down to the minimum for the rest of the car.
Sun Apr 12 2020 10:58am |
Located in Cornwall. In response to others...done the sniff and bubble test, both negative. Just ordered a tell tale kit which detects exhaust gas in the water. Should be interesting. Steel seal is my choice of aperitif having done the diligence. As I've said before performance is great and no oil usage. Header bottle changed along with cap which is now kept loose. Water level in bottle always been very low. Seems to find it's own level no matter how much water you put in. Maybe I'm over filling and it doesn't like it. Cheers. D |
Sun Apr 12 2020 1:22pm |
