Home > Faults & Fixes > Weird Accelerator |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8958 |
It's a well known issue, sadly. It annoys the hell out of me at times.
Fri Mar 13 2020 5:05pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I read on the Disco3 forum that putting it in Sand mode makes for a sharp getaway from junctions/roundabouts when needed.
Fri Mar 13 2020 8:52pm |
Just sticking it in 1st gear will do the job most of the time. 2012 SDV6 - it's missing a couple of cylinders
Fri Mar 13 2020 9:05pm |
willster174 Member Since: 11 Mar 2020 Location: Peterborough Posts: 12 |
So does that mean there is no fix for it?
Sat Mar 14 2020 11:34am |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 200 |
Two fixes I have a MY12, Sport mode or Alive Tuning. 2018 Telsa MS
Sat Mar 14 2020 6:52pm |
This problem is intermittant at all times not just when pulling away.
Mon Mar 16 2020 10:29am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4958 |
As you proably have a AMK Compressor fitted it is quite likley the mounting bushes are worn, and this kit is the sort of thing you need. L/R used to do a kit LR061888 however that number is no longer any use as it now relates to the complete compressor.
Mon Mar 16 2020 11:31am |
Hi Col
Mon Mar 16 2020 11:58am |
I think you need to confirm it is a Amk compressor and not Hitachi first, easy enough just drop plastic cover and look at how it's mounted to chassis as both totally different. Not sure when they started fitting the Amk, but I think it was from Vin. BA708255 on, although they did revert back to the Hitachi for a short time during MY12/13 production.
Mon Mar 16 2020 9:34pm |
Might be worth getting the throttle pedal potentiometer checked in some way if possible, only a suggestion. Do you have any fault codes like PO123-00 or similar? Cheers Col |
Mon Mar 16 2020 10:52pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Or 05 supercharged does that with the accelerator sometimes. If I've just switched it on and after a few minutes I blip the throttle, nothing happens. Second time it's OK. Its almost like the engine is catching up with the pedal if the see what I mean. |
Thu Mar 19 2020 6:24am |
