Home > Faults & Fixes > Noisey ACE pump |
Malc H Member Since: 18 Feb 2020 Location: Bristol Posts: 6 |
Hi did you ever find the cause of the noisy ace Pump?
Tue Feb 18 2020 10:02pm |
No, I replaced the entire system bar the actual sway bar actuators. I’ve now come to live with it 😂 |
Tue Feb 18 2020 10:11pm |
Thank you for your speedy response.
Tue Feb 18 2020 10:39pm |
When is it noisy? It’s a pretty simple set up. 2012 5.0 SC AB
Fri Feb 28 2020 3:35am |
Hi its very noisy above 1000rpm it emanates from the ACE.Pump new one fitted slightly better at first but now exactly the same.
Sun Mar 01 2020 11:40pm |
Defo from the pump? lots of other parts in this area and noise travels! 2012 5.0 SC AB
Mon Mar 02 2020 3:14am |
yes sadly
Mon Mar 02 2020 6:24pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4347 |
When was the filter in the valve block replaced? |
Mon Mar 02 2020 9:04pm |
at the same time the valve block was changed by the LR dealer |
Mon Mar 02 2020 10:49pm |
Does the sound change if you take the cap off the reservoir? The system is so simple that at rest, the pump just pushes fluid to the valve block and it’s then returned to the reservoir and back to the pump. Can you see the fluid returning to the reservoir at idle?
Tue Mar 03 2020 12:00am |
Have checked today, the sound does not change with the cap off and there is a healthy flow of fluid.
Sat Mar 07 2020 11:44pm |
Baz0195 Member Since: 29 Jun 2018 Location: Telford Posts: 23 |
Hi there. I had my front ACE pipes replaced on my59 2010 shape RRS and ever since then I’m getting a noise from under the driver’s side foot-well when cornering it’s like a metal on metal sound which I thought was coming from the wheel but it has been looked at by my indie & had the front wheels & brakes apart tried a new Wheel bearing but still doing it. I was told that it could be coming from the ace as it sounds like fluid in Pipes kind of noise which now makes sense as it started just after the ACE pipes was changed, I had to have the car back as it in for an mot tomorrow & the indie had to carry on with there other customers, it’s booked back in on Thursday, any ideas what it could be would be much appreciated ðŸ‘🻠|
Fri Jun 05 2020 7:01pm |
Check the rubber mounts are 1, present and 2, intact. There should be 2 on the pipes behind the wheel And one clamp near the front body mount under the drivers side. If the fitter re-used the original mounts, there’s a good chance they were goosed when he removed them. If they are good, check the valve block mounts are good and that the pipes are not touching the body or chassis. There’s at least 4 or 5 different front ace pipes so have they fitted the correct version? 2012 5.0 SC AB
Fri Jun 05 2020 11:47pm |
