Home > General (L494) > WATER IN BATTERY TRAY IN BOOT |
Tiger Member Since: 16 Aug 2017 Location: Moscow Posts: 6 |
Open the trunk trim on the left and right.
Fri Nov 08 2019 3:13pm |
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 167 |
what do you mean where are pipes located |
Mon Nov 18 2019 5:40pm |
can you tell me more about this |
Tue Nov 19 2019 5:20pm |
Check behind the rear doorways for these tubes. Left and right in the Luggage compartment.
Tue Nov 19 2019 9:12pm |
do i have to remove carpets to see them pipes or where are these exactly thanks |
Tue Nov 19 2019 11:01pm |
can you tell me exactly where these are right and left and do i have to remove carpets |
Wed Nov 20 2019 1:29pm |
GOT THEM BUT WERE FINE THANK YOU |
Thu Nov 21 2019 4:38pm |
Highlighted in red these tubes.
Mon Nov 25 2019 5:04pm |
checked them but perfect all in tact and clear not blocked |
Mon Nov 25 2019 5:07pm |
And in the compartment under the battery, under the pneumatic compressor there is water? |
Mon Nov 25 2019 5:12pm |
yes but where is it coming from ,all sunroof drains are fine and checked , battery tray itself can get full of water , new boot seal ,sealed behind number plate |
Mon Nov 25 2019 5:28pm |
any other ideas where this might be coming from |
Thu Nov 28 2019 4:21pm |
any idea where else |
Wed Dec 25 2019 9:33pm |
