Home > In Car Electronics > Thinkware U1000 Dash Cam |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4873 |
Just updated my Thinkware F770 Dash Cam to the new U1000, no particular reason just thought it was time for a change as the F770 must be well over 3 years old now. Was it worth it, No not really cosmetically it looks a little nicer rather than a rectangle box, better image from camera being 4K but that's about it, otherwise does just about the same as the F770 except twice the price. There is a additional motion detecting radar unit you can buy extra for it, which is basically a energy saving device when in Parking Mode which wakes the camera up if motion detected, only trouble is it only works if motion is detected at front of vehicle not the rear. Going to try a 250GB card in it to see if it works but is listed as only taking up to 128GB. One bonus is it uses the same hardwire power feed and cable for rear camera so no rewiring. Generally nice camera but to expensive to recommend buying one at the moment, maybe when price drops, but have to admit the F770 is a very good camera apart from looking a bit dated will take some beating. Forgot to mention due to the high resolution or whatever of the camera the PC viewer can't show both front and rear images at the same time on the screen.
Mon Dec 23 2019 9:47am |
Yeah, the silver button show in the picture is the manual record button.
Mon Dec 23 2019 10:55am |
Looks more visible than the one on the 770 Andy.
Mon Dec 23 2019 10:57am |
That one's o.k. the others wifi, power etc are bit difficult to see same as the F770 though, would have been better if they were a slighty different colour but not a major issue.
Mon Dec 23 2019 11:08am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I've commented before about this slight niggle with the F770. I would have thought it wouldn't have been too difficult to provide them with gentle LED back illumination when the engine is running. Interesting to hear that you still rate the F770. Guess I'll save my pennies for now. Robin
Mon Dec 23 2019 1:51pm |
Yeah, personally still rate the F770 as one of the best and it will take some beating, a few extra features on the U1000 that probably never use anyway, bit like a lot of things these days just gimmicks that are not really needed. Meant to say they appear to have improved the GPS connectivity on the U1000 as it only takes a few seconds to connect now has even done it with car parked in the garage on a couple of occasions.
Mon Dec 23 2019 9:50pm |
Should it be of any interest to anybody have tried one of these Sandisk 256gb cards in camera and works fine although spec. says max. 128gb.
Mon Dec 30 2019 4:15am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Nice feedback, guess I will stay with the 770. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Dec 30 2019 9:37am |
256gb card just stopped working so may not be compatible after all, been alright for a few days, I think it may have been after I tried it in the F770 as a experiment can't really see that would have done anything to the card though, re-formatted it but still not working will get another 256gb and try it, if that doesn't work not a real problem will just have to stick with 128gb one's.
Thu Jan 02 2020 3:21am |
May be of use to someone, but just had another play with 256gb instead of the maximum 128gb card Thinkware say it will accept, a new 256gb card works fine, however if you re-format the 256 card using the camera app via a smartphone or PC viewer (The camera it's self no longer has the Format button on it unlike the F770) it does something to the card and it will no longer work for whatever reason even if you do a full re-format on a PC. If however you only ever re-format the card using a Windows PC it will work fine. Don't really know why this should be the case but that's what seems to happen, just thought it might save somebody wasting a card, although the card still works just not in the camera. I suppose the obvious solution is buy a couple of 128gb card and just swap them over.
Fri Jan 24 2020 9:50am |
Very interesting Col. I wonder if Thinkware are aware. Robin
Fri Jan 24 2020 9:52am |
Robin, I'm inclined to think if anyone actualy mentioned it to Thinkware they would just say but it's only supposed to accept a maximum 128gb card.
Fri Jan 24 2020 10:02am |
Robin
Fri Jan 24 2020 11:36am |
Col I’m about to hardwire my 770 into my RS,can you remind me which of the 2 wires red & yellow is the permanent live & which is switched live.? Andy.
Thu Jul 30 2020 4:18am |
