Home > Maintenance & Modifications > Modiying ccf file to show warning when dpf is regen..can it |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
have a look on the fullfat forum, especially in the L322 section..loads of info there re dpf.. |
Thu Dec 12 2019 12:12pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Thanks scary |
Thu Dec 12 2019 3:49pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
You can tell when a DPF regen is happening if you are in tune with your engine and exhaust note. You will notice that it will sound more throaty due to the extra fuel being injected. Kev
Fri Dec 13 2019 1:05am |
what if you have the radio on , you wont hear anything... |
Fri Dec 13 2019 9:14am |
Lol ..exactly...cant be driving around with radio turned off just so I can keep an ear on the engine note... |
Fri Dec 13 2019 10:33am |
I prefer to listen to my car over the crap that gets broadcast on the radio, but that's just me
Fri Dec 13 2019 5:41pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
The standard OBD2 parameters contain parameter 44 ("Commanded EGR") but I don't know if this is actually used by LR (use is not mandatory); the fuel:air ratio (lambda) might be a proxy indication, as might exhaust gas temperature. I've done a couple of DIY-based OBD projects in the past using the ELM327 chip to do the heavy-lifting. It might even be possible to establish a BlueTooth™ link with one of the £4 Chinese OBD interface boxes using some sort of microcontroller (I don't know if the datastream is presented simply). All of these seem a bit of overkill and disproportionate to the impact of an event with a low probability of occurrence - what percentage of a car's running time is with a regen occurring? Small impact x low likelihood = not a massive problem in my book.
Sat Dec 14 2019 5:09pm |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 |
Buying an OBD tool that can command a regen and then going for a monthly run down a dual-carriageway in a low gear might be a better means of re-assurance - a cleaner DPF is going to be even less affected by an interrupted regen.
Sun Dec 15 2019 10:01am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
The IID will show exhaust temps and soot mass and shows when former rises and latter lowers.
Sun Dec 15 2019 10:12am |
Thanks DrRob
Sun Dec 15 2019 9:09pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 750 |
"If this was something to worry about, surely someone, somewhere, would have implemented it as a factory-fitted feature":
Mon Dec 16 2019 12:32pm |
Thats exactly my thoughts...car manufactuers will not admit to design faults...and this is a design fault...I would rather know my car is doing regen by means of a message on drivets screen etc...rather than risk oil dilution from failed regens which is what I am angling for. |
Mon Dec 16 2019 11:34pm |
