Home > General > TPMS |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
behind the headlights
Thu Nov 07 2019 8:26pm |
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 |
Ok. Will take a look at the weekend. Thanks mate ===========================================
Thu Nov 07 2019 8:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4874 |
Should be a plug up in the roof panel under the front interior light consul, can't remember what colour the plug is though. The TPMS system on the RRS1 is pretty useless, just tells you which wheel is down on pressure and that has to drop to around 25psi before it registers, that's it nothing else doesn't even show actual pressures. Did intend to change mine for a superior aftermarket one but never got round to it.
Thu Nov 07 2019 9:15pm |
I’m happy to look at an after market system. Any suggestions? ===========================================
Thu Nov 07 2019 9:20pm |
Violet plug by the looks of it.
Thu Nov 07 2019 9:29pm |
Thanks mate. Yeah that box in the car look hideous. Don’t mind the valve caps but yeah could not have that box in the Range. Need something a little more factory look or smaller device in side the car. ===========================================
Thu Nov 07 2019 9:40pm |
If I read the Steelmate advertising correctly you can integrate it into the headunit/screen, but not to sure whether can do it with the Sport. I might well buy one and see.
Thu Nov 07 2019 10:00pm |
Where you looking at buying from? If not mega expensive I might give it a go as well. ===========================================
Thu Nov 07 2019 10:12pm |
Could try here in the UK look to be around £160.00 so not the end of the world if doesn't work. I will proably be lookin at OZ personally, could pick one up on one of my trips over there.
Thu Nov 07 2019 10:22pm |
Might give it a blast. I’m guessing the Range has a rca connection somewhere to plug in to? ===========================================
Thu Nov 07 2019 10:26pm |
I was wondering if it was possible to use the ones in the rear aux panel under the flap between the front seats if they are also inputs, to see if would at least work, not a audio/visual engineer though.
Thu Nov 07 2019 10:48pm |
Interesting. Will add this little mod to my list of items. ===========================================
Thu Nov 07 2019 10:54pm |
