Home > Technical > Rear brake plate/splash guard replacement
Fictivision
Norway 2006 Range Rover Sport TDV6 HSE Java Black
Splash guards on my RRS 2006 have rusted so badly they start falling apart. Anyone know how hard are they to replace?Are they only held by some bolts or I need to take off brake calippers and brake discs too in the process?
It is the rear splash guards that needs to be replaced.
thanks in advance
Post #587726 Sat Sep 28 2019 8:14pm
Brit Plumber
They are bolted on but they are usually rusted so you need new screws/bolts. Now the bad bit, you need to split the bearing so you need to fit new bearings too. If you’re not in a rush, keep an eye on ebay as genuine parts can sometimes be available quite cheap. I picked up a New genuine LR rear bearing for £8 back in April and I’ll be fitting that when I do my rear brake splash shield. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #587728 Sat Sep 28 2019 9:09pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
just replaced mine, big job replacing bearings, epb shoes, abs sensor, and some bushes.
Wonder why the easy option is only available across the pond
https://www.roverparts.com/Parts/PARKBRAKIT02
Post #587731 Sat Sep 28 2019 9:19pm
knwatkins
That's because the split shields are an Atlantic British custom designed and manufactured part Wink Kev
Post #587746 Sun Sep 29 2019 8:56am
Fictivision
Oh my,so much for an easy job Smile
Post #587747 Sun Sep 29 2019 8:59am
get normal ones and cut them where Atlantic British have.
May need to tack weld them together if you have the equipment
Post #587754 Sun Sep 29 2019 11:10am
Fictivision
Great,thanks for the tip. Will see what I can do.
Post #587760 Sun Sep 29 2019 5:10pm
