Home > My Range Rover Sport > 1 week with my RRS |
ToonArmyMick Member Since: 04 Sep 2019 Location: South Shields Posts: 7 |
Hi Everyone,
Thu Sep 12 2019 7:45pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
It sounds like your battery has been disconnected so you will need to reset your windows. Close them, release the window switch then pull the switch up for a couple of seconds and that will reset them to 'one touch'. Kev
Thu Sep 12 2019 8:04pm |
Hi and welcome
Thu Sep 12 2019 8:44pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
As has already been said,, 5 min job to reset your windows, but my drivers door mirror also appears to not fold in as far as the passenger's side,,, it's always been like that. I just assumed that was the was it was supposed to be. 2010 RRS, TDV8
Fri Sep 13 2019 4:33am |
They don’t do much with the engines now. Mine just had a small diameter SC pulley and a re-map which I suspect are sub contracted from OF. The OP body kit is the standard RRS dress up kit found on the Autobiography and Lux etc. The interiors usually get a makeover with a few OF marked items thrown in such as the clock, the instrument cluster and luxury matts (and I think those are Range Rover ones rebadged with OF badges). I wonder if this one came from Autolab in Blackburn? 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Sep 13 2019 7:18am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Now that's what you call a garage Wish mine was that size |
Fri Sep 13 2019 11:25am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
I thought they were pictures taken at the supplying dealer, it's that big! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Sep 13 2019 12:13pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Hi
Fri Sep 13 2019 6:10pm |
It does look nice,I’m just in the process of putting a new unit up similar to rent out,now I’ve seen yours I might just keep it myself to put the sport in even though I’ve also got this
Fri Sep 13 2019 6:24pm |
Starting to get garage envy |
Sat Sep 14 2019 7:19am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 467 |
I don't have one at all.
Sun Sep 15 2019 1:44am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1245 |
That’s not a garage that’s a Hangar! . Helicopter outside is it
Sun Sep 15 2019 6:52am |
Assuming around Brid? I've always wondered what the rent on a unit like that would be .. not that I'm in any position to rent a unit for anything at the moment, and definitely not in your neck of the woods but I wonder if you'd mind sharing a ball-park (via PM)? Half idle curiosity, half bitter disillusionment with my current line of work 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Sep 16 2019 5:23pm |
Hi Everyone,
Fri Oct 09 2020 5:51pm |
