![]() | Home > General (L494) > Bonnet open warning along with low coolant and water in fuel |
Aguiness Member Since: 31 Dec 2018 Location: Stirling Posts: 49 ![]() ![]() |
Hi
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 578 ![]() ![]() |
brand new in the summer |
Anyone help |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 260 ![]() ![]() ![]() |
Bonnet switch perhaps?
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Weird electronics goings-on are often down to either battery voltage (worth checking it, even though the battery is quite new) or water ingress into an ECU connector somewhere. Any signs of water ingress in the footwells or elsewhere? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
carpets all dry , also does not want lock off the remote but after around 15 mins you can lock the car .
Driver s side headlight not working either |
Topped the coolant up and changed the bonnet switch and guess what the warning lights are still on |
Changed tonight and is still the same ![]() ![]() ![]() |
Anyone help ??? |
I had assumed that you have had the codes read but re reading the posts I cant see that you have.
Shippey1974 Member Since: 25 Apr 2020 Location: west Yorkshire Posts: 4 ![]() ![]() ![]() |
I have just started with this issue and after I went through a Ford so the water ingress is a real eye opener for me. but it is very intermittent |
Turned out to be nearside headlight earth under the inner wing |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 529 ![]() |
Thanks Red Arrow for letting us know the reason... it’s why this forum works!
