Home > Maintenance & Modifications > Hydraulic Oil Leak Above Rear Diff |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Maybe slightly aggressive?
Tue Jul 30 2019 9:24pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
I'll take a pic of what I used as soon as I can. |
Thu Aug 01 2019 12:21am |
"fixing the f-ing thing" is not always something that can be done right away. If the OP could "fix the F-ing thing" he would do it and not post here. We're offering temporary solutions to help offest the urgency. De-articulating rear sway bars are "F-ing" expensive so chill. |
Thu Aug 01 2019 12:24am |
This is what I used and it worked very well I might add. |
Thu Aug 01 2019 11:16am |
BaysideG Member Since: 06 Aug 2019 Location: Poole Posts: 14 |
Out of interest, given this is for power steering systems, what protocol did you use for it? Ordid you just dump a load into the Dynamic Response reservoir and hope for the best? 2012 RRS Autobiography Sport SDV6 Orkney Grey |
Mon Sep 09 2019 10:05pm |
Have you got problems with this too? My rear ace bar is leaking, hoping to get it fixed under warranty but.... 2012 RRS Autobiography Sport SDV6 Orkney Grey |
Mon Sep 09 2019 10:06pm |
Yup, I just put it into the resevoir and filled it to the specified line. I checked it every day and topped it off. The first day it still leaked but as I kept topping it off it leaked less and less. By the fifth day it stopped leaking so i went through the off road settings and de-articulated the sway bar went over a curb carefully about 5 times and then parked it in my garage. The next morning i checked underneath and no leak. This bought me 4 months to save up for the repair and all has been good since. My leak was very small and slow so try it. If it doesn't work it doesn't work but at least you tried. And for the record, the fluid in the resevoir IS power steering fluid and once it gets to the shop for the real repair it won't matter anyway because they will flush the fluid out. Make sure you ask them to flush it though in case they, you know, "forget". |
Tue Sep 10 2019 3:30am |
Great! Interesting, thank you! 2012 RRS Autobiography Sport SDV6 Orkney Grey |
Tue Sep 10 2019 7:39pm |
