Home > Maintenance & Modifications > Hydraulic Oil Leak Above Rear Diff
Silvercell
Hi everyone Im looking for information on how to replace the rear stability control bar on 2010 model. It is leaking hydraulic fluid and needs replacing. Is there a fix for these that you can do without lifting the body up? or a way to bypass the system?
Thanks
Post #584208 Sat Jul 20 2019 6:48pm
Disco_Mikey
The system can be bypassed successfully on 2.7 and 3.0 models
Never attempted a 3.6 removal yet, but I think I have a way to do it, just need a car in to try Thumbs Up
However, to replace the bar, the rear body need lifted off the chassis, and removed out the side. You'd be well advised to replace the rear pipes at the same time, save you doing the same job twice Thumbs Up
Post #584212 Sat Jul 20 2019 7:25pm
Silvercell
Thanks for the reply Disco Mikey, how do you bypass it and is there a kit or something to do it? Can it be done without lifting the body up?
Thanks Smile
Post #584215 Sat Jul 20 2019 7:46pm
Disco_Mikey
2 ways, either bypass the system but leave the hydraulics in place, or do it properly and replace the bars with standard non hydraulic parts Thumbs Up
Post #584219 Sat Jul 20 2019 8:58pm
Silvercell
Could you tell me how to do it both ways please and what the drawbacks are, and it if throws suspension fault codes up etc. I need to give customer both options.
Many Thanks
Post #584223 Sun Jul 21 2019 12:20am
Disco_Mikey
What diagnostic system are you using?
Post #584229 Sun Jul 21 2019 7:01am
Silvercell
I believe its the Launch diagnostics my boss has, Ive not long been working at this new place. There is the Delphi diagnostics as well.
Post #584249 Sun Jul 21 2019 3:32pm
Disco_Mikey
Either of them will allow CCF editing nor the required firmware updates...
Post #584250 Sun Jul 21 2019 3:43pm
Silvercell
So does that mean it will have to go on the dealers diagnostics after the repair?
Post #584251 Sun Jul 21 2019 3:49pm
Disco_Mikey
The dealers cannot alter the CCF or upload the "wrong" firmware to the car
Post #584252 Sun Jul 21 2019 4:09pm
Silvercell
Which diagnostics is it that allows you to do this? Thanks
Post #584253 Sun Jul 21 2019 4:16pm
DrRob
Silver cell - take it to Disco Mikey to fix Thumbs Up Visitor from fullfatrr.com
Post #584260 Sun Jul 21 2019 7:14pm
Silvercell
Unfortunately Disco Mikey is too far away.
Post #584264 Sun Jul 21 2019 7:59pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
I had a leaking Ace system and until I was able to have the rear sway bar replaced I just bought some of the fluid from the dealer and then bought Lucas Power steering leak stop or something like that and used it in my ace system. The leak stopped and lads, before you all go flaming me for putting foreign fluids in the ACE system, let me tell you that this was a recommendation found on other Land Rover forums and it really worked. The warning disappeared, the leak stopped and all went back to normal. A few months later I replaced the Rear sway bar (not cheap at all) and everything is working as it should.
Bottom line; If this is a surprise repair then try the Stop leak additive and see how you fare. If it's a small leak you should be fine for one or two months. Plenty of time to save up for the rear sway bar Wink
PM me if you want an actual picture of what I used.
Post #584683 Tue Jul 30 2019 6:47pm
knwatkins
That's very useful to know. Please post what particular fluid you used. Kev
Post #584686 Tue Jul 30 2019 8:58pm
