Home > General > Towing electrics |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4817 |
you have a late model, which I believe doesn't have fuses in the rear for the towbar.
Wed Jul 10 2019 7:54pm |
Akitamum Member Since: 15 Jun 2019 Location: Cheshire Posts: 17 |
Thanks Andy,unfortunately all fuses are fine |
Wed Jul 10 2019 8:40pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Have you tested the RRS with another caravan or trailer, or tested the caravan with another car? Is it definately the RRS with the problem and not the caravan wiring?
Wed Jul 10 2019 8:51pm |
Caravan was tested with another vehicle on Sunday and all was fine so definitely the RRS,we've had it to an auto electrician today explained the problem and asked to change to 13 pin as well,took it up to the caravan this evening and still the same so will be going back tomorrow,when it had the N & S sockets we tested on a trailer board and the same on that also. |
Wed Jul 10 2019 9:04pm |
Sorry side lights don't come on either car or caravan when connected |
Wed Jul 10 2019 9:06pm |
If an auto electrician changed from the 12N&12S to 13pin just today then I would presume (hope) he tested the socket with a tester of some sort?
Wed Jul 10 2019 9:34pm |
All seems a genuine plug and play kit, we had the side panel and left rear light out the other day.
Wed Jul 10 2019 9:58pm |
Are you handy with a voltmeter as it'd be worthwhile working through the pins looking for voltages as per the diagram. 13MY Range Rover Sport Autobiography SDV6 - mine
Wed Jul 10 2019 10:41pm |
Well check the side light wire with a test lamp in the rear left quarter
Wed Jul 10 2019 11:04pm |
We haven't done on this one as yet,though did on the 7 pin and 5 & 7 had nothing,we had no idea where to go from there hence why taking it in today, really seems like they have just swopped the socket and not checked anything. |
Wed Jul 10 2019 11:07pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
Any help? I think these are the plugs behind L/H boot panel, I assume there is no issue with the vehicle side lights with the caravan dis-connected.
Wed Jul 10 2019 11:14pm |
I’m still saying it’s a fuse by glovebox. |
Thu Jul 11 2019 12:03am |
If the side lights are working on the vehicle that only really leaves fuse No.27 Trailer Side Lamps, if not then it has to be 24 & 25.
Thu Jul 11 2019 12:11am |
Blown fuses would be a good result, but why would the RRS side lights work ok without trailer connected, but not when connected? That's the bit that's confusing me, it often can be a short, but if it's fused and no blown fuses....... 13MY Range Rover Sport Autobiography SDV6 - mine
Thu Jul 11 2019 12:12am |
