Home > General > suspension question...... |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
normal, self levelling |
Sat Jun 29 2019 9:59pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Normal. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Jun 30 2019 4:51am |
Macca Member Since: 03 Oct 2016 Location: Nottinghamshire Posts: 17 |
Def normal, should notice the back end gently drop D3 TDV6 SE auto 2006
Sun Jun 30 2019 6:53am |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 |
Thanks guys , figured it might be normal but as only just started after new compressor was fitted was getting a little concerned that there was a secondary issue, especially as it was loud enough for a colleague to hear in the car park about 30ft away
Sun Jun 30 2019 11:31am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1066 |
You didn't need to buy a new compressor - you could have drilled out the sheared exhaust valve and put the new one in.
Sun Jun 30 2019 1:17pm |
Garry, sadly as I needed the RRS quickly and the repair kit I got only had the internal spring and rubber bit I was up the proverbial without the necessary paddle
Sun Jun 30 2019 7:49pm |
My exhaust valve also snapped off but in doing so the crud that was stopping the valve from closing dislodged so it started working even though the hex head was broken off. I have a new valve and hex housing ready to go if the compressor plays up in the future.
Mon Jul 01 2019 1:49am |
Garry, just to let you know that yes the the exhaust pipe was loose from the compressor, guessing i hand't pushed it fully home, and then knocked it off when fitting the cover.
Thu Jul 04 2019 12:38pm |
