Home > Maintenance & Modifications > Front brake slider pins |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
This might help.
Thu May 16 2019 5:49pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 747 |
Thanks for that Col, looks like they just pull out Got Bods'y brake bible all ready to go.
Thu May 16 2019 9:08pm |
I use a set of thin long nose grips to hold the slider from spinning.
Fri May 17 2019 7:49am |
I think Iv'e got it now, if a 17mm spanner won't fit on the inner nut, use mole grips on it, not on the slider pin gator. |
Fri May 17 2019 4:31pm |
Don’t put the grips on the gaiters as they could split,between the gaiter & the calliper their is enough to get a 17mm spanner or some thin grips like I use. Andy.
Fri May 17 2019 5:01pm |
Thanks for that, I will have a look Sunday or next week, weather permitting. |
Fri May 17 2019 10:32pm |
