Home > Maintenance & Modifications > Active Roll Control Module |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
i would try and 2nd hand one if cheap |
Sun May 12 2019 4:16pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The Dynamic Response Control Module contains two tunes - one for the TDV8, the other for TDV6 and petrol versions. Presumably the weight of the TDV8 is sufficient to require a different set up. The choice of tune is selected when the module is first installed. I wonder if this is what they are referring to. It might be worth trying a 2nd hand TDV6 one if you can find one cheap enough. Obviously avoid one from a TDV8 in case the tune choice is a one shot deal. 2012 SDV6 - it's missing a couple of cylinders
Mon May 13 2019 5:21pm |
not all TDV6 had active though. |
Mon May 13 2019 6:16pm |
Then there won't be a module to fail, will there?
Mon May 13 2019 8:19pm |
Even a second hand one can be reprogrammed! It’s just an EPROM so worst case is just need a reflash. Why are they saying the module is stuffed? 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Tue May 14 2019 11:34am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Lean error on the dashboard with
Tue May 14 2019 11:51am |
It did look like it was permanently on a side slope in Wales! 2012 SDV6 - it's missing a couple of cylinders
Tue May 14 2019 11:53am |
Is it defo C1A00-01 as that code suggests an issue with the wiring harness or damaged isolation switch. -04, 43,45,46 would be associated with a module internal failure. Have you checked the plug at the terrain switch? 2012 5.0 SC AB
Tue May 14 2019 9:42pm |
That's what came up on IID that I captured back in Feb though they have subsequently used another tool(s) to come up with their prognosis. The wiring & plugs have all been checked. |
Wed May 15 2019 11:28am |
