Home > Technical > Towbar play
Flexzor
Belgium 2009 Range Rover Sport TDV6 HSE Java Black
Towbar play
I have just started using the towbar on my 2009 2.7 tdv6 sport. It was never used before and is therefor brand new...
However.. there is play on the towbar. Anyone has an idea how to solve this?
I'm quite sure the locking mechanism is well locked.
Thanks
Post #580668 Sat May 11 2019 5:11pm
Chugga90
Clean receiver hole thoroughly?
Could be surface rust or grim stopping it fitting correctly.
Do not use it for towing until fully home and lock fully engaged. Thumbs Up
Post #580687 Sun May 12 2019 8:34am
Mine lock's in o.k. with no undue movement but bought one off these as a precaution, as I believe they have been known to drop out.
https://www.advancedfactors.co.uk/kit434-s...0032-p.asp
Post #580688 Sun May 12 2019 8:48am
geoffsnook
Yep mine dropped out along with my twin axle of the back and there was no play in it and was attached securely so take no chances Thumbs Up
Post #580689 Sun May 12 2019 10:15am
