Home > Technical > 2010 RRS Windscreen Wiper (arm) issue |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
Will ask the obvious, is the securing nut tight (18Nm.)?
Mon May 06 2019 11:10pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
A fair question, it's as tight as I can make it but rusty as anything so I didn't want to use too much force! |
Mon May 06 2019 11:14pm |
Possibly damaged the splines beyond use so it may well be a new arm and maybe pivot if it’s available as a separate part. 2012 5.0 SC AB
Mon May 06 2019 11:19pm |
Yeah, might find it's worn away inside the arm especially if it's been slightly in the past and the retaining nut's bottoming out. Spindle/shaft not available separate, new linkage £140.00 from L/R even the arm's stupid money at £40.00 from them, think I might look on fleabay first.
Tue May 07 2019 4:46am |
That sounds like a sensible course of action, any idea on the part numbers I need to look for.
Tue May 07 2019 6:55am |
I think the arm is DKB500060PMD but may have been superceded by now, linkage was DLS500030 now LR038347 will double check numbers later.
Tue May 07 2019 7:45am |
