Home > General > Good independent garages in kent? |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
Didn't have it long enough to get an oil & filter change so can't help I'm afraid.
Wed Apr 17 2019 8:41pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 467 |
I will be there on the morning of the 24th, for a while you wait oil & filter change, they use Morris Multivis C1 ADT 5W30 fully synthetic, I have read up on this and it seems to be perfect for the engine.
Wed Apr 17 2019 9:19pm |
Wed Apr 17 2019 9:22pm |
Update as promised...
Thu Apr 25 2019 5:55pm |
Appreciate you taking the time out to update on your visit to AHL. When I spoke to Harold he did mention that Angus was the "expert" which is supported from the conversation you had with him. Took a drive there last week as mine was potentially going to be towed there and I was concerned that the rural location may cause an issue for the recovery driver - if you avoid coming in via Lenham its not that tight. Looked a decent enough set up from what I could see from the gates.
Sat Apr 27 2019 7:36am |
