Home > In Car Electronics > 4x4 info screen
Brit Plumber
4x4 info screen
Ok, daft question, anyone know how to activate the 4x4 screen using the GAP IID tool? I’ve been through all the menus and I can’t see an obvious “4x4 info screen” option so it must be in an obscure selection. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #578092 Fri Mar 29 2019 12:01pm
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
This might help
https://www.gap-diagnostic.com/support/medias/
Then select video 3, it shows you how to enable the 4x4 screen.
It looks like the 4x4 info screen is in the ACM Audio system sub menu.
Post #578097 Fri Mar 29 2019 1:52pm
Brit Plumber
Thanks for the link, it confirms I was looking in the correct place but it’s not there. I’ll have to email GAP and see why. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #578099 Fri Mar 29 2019 4:20pm
david007
Check that you’ve got the latest update downloaded to the tool.
I was going to check to see what i’ve got on mine but the wife is using the car today.
Post #578100 Fri Mar 29 2019 4:33pm
Dont range rovers have it as standard.
Post #578106 Fri Mar 29 2019 6:09pm
Brit Plumber
That’s what I thought. I just wonder if I have a problem. No faults logged though.
I don’t even get an ACM menu on the GAP tool so trying an update.
Top photo is from Demo, bottom is my report.
 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #578108 Fri Mar 29 2019 6:39pm
david007
That’s a bit strange.
I’ve just had a look at mine and this is what I can see.
Post #578111 Fri Mar 29 2019 7:10pm
Brit Plumber
Just done an update and I now have ACM. Unfortunately I do show 4x4 screen enabled, but it’s not. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #578112 Fri Mar 29 2019 7:33pm
Brit Plumber
Sorted it,
I fitted dual View last month but as I was unsure if it would work, I bought a cheap one with a damaged screen. When it worked, I bought another with a good screen and that’s the one I had issues with. It came out of a 2013 sport so should have had the 4x4 info. Even with it enabled in the CCF it wouldn’t appear. Putting the damaged screen back in, showed it not to be a car issue. So I’ve changed the actual LCD display screen between units and it works fine now.
So it appears not all RRS had the software in the FCDIM for 4x4 info. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #578133 Sat Mar 30 2019 9:59am
