Home > Maintenance & Modifications > Dynamic Fluid |
Probably better off pm’ing Disco mikey,,he will know Andy.
Thu Mar 21 2019 9:27pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4794 |
Thu Mar 21 2019 9:28pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Buy the power steering fluid from the dealership. It is the same stuff. |
Thu Mar 21 2019 10:06pm |
Kems Member Since: 20 May 2018 Location: Torquay Posts: 13 |
Thanks all |
Fri Mar 22 2019 9:41am |
If it’s low, how low and where’s it gone? 2012 5.0 SC AB
Fri Mar 22 2019 8:55pm |
Usually it leaks via the rear sway bar.... A pricey fix but you can delay the leak and buy yourself some time to save up by buying Power steering fluid stop leak. Lucas Works quite well but don't think you can get away with it being a permanent fix. Sooner or later that sway bar will have to be replaced. |
Sat Mar 23 2019 1:07am |
I don’t think u should put stop leak into the ace system. |
Sat Mar 23 2019 8:39am |
It's been done by a few people on this forum.... When I did it and had the dealership replace the sway bar nothing happened. Just don't think of it as a long term or permanent solution, that's all. Rear De-articulating sway bars aren't cheap. |
Sat Mar 23 2019 9:43am |
