Home > General > Lower front suspension arm bushes MoT advisory |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Better value for money I think changing the whole arm, there is a "how to" somewhere on here on how to do it, maybe on the disco site as well 2010 RRS, TDV8
Sat Mar 02 2019 7:10pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
change the whole arm.
Sat Mar 02 2019 9:58pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1246 |
Think Advance Factors do different ones with a different length of warranty.
Sat Mar 02 2019 10:13pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 756 |
Just because it's an advisory doesn't necessarily mean they are shot. If it doesn't knock when the brake pedal is jabbed at low speed, they may still be ok. Some MOT testers will put it down when it's fairly normal movement. A really good indi will give you a better idea. |
Sat Mar 02 2019 10:24pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Change the whole arms. The bolts where seized in the bushes on mine so I ended up cutting the bolts with a reciprocating saw and smothering the replacements with copperslip to prevent them seizing again. Kev
Sun Mar 03 2019 6:00pm |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 |
Don’t buy cheap parts either. I bought my car and there were new arms and receipts to match. Within months they were making a horrendous squeaking noise. I replaced them with original LR parts - still fitted and not a squeak. Previously owned 1999 Disco 2 TD5 Disco 3 HSE TDV6 2007 Gone 2007 TDV8 RRS1 in Buckingham Blue. How do know if the knocking at the front has been sorted? You can hear the knocking at the rear better |
Mon Mar 04 2019 3:03pm |
Age old saying,,,, you only get what you pay for 😉 2010 RRS, TDV8
Mon Mar 04 2019 5:28pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
"Buy cheap, buy twice". 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 04 2019 7:07pm |
johnrambo Member Since: 30 Jan 2019 Location: scotland Posts: 27 |
arms are not expensive
Fri Mar 08 2019 6:02pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
We fit Meyle HD to everything now |
Fri Mar 08 2019 6:57pm |
equivalent quality and strength to OEM? 2007 TDV6 RRS HSE..now gone
Sat Mar 09 2019 12:35am |
Never had one come back with any issues or needing replacement |
Sat Mar 09 2019 8:02am |
good to know.
Sat Mar 09 2019 6:43pm |
We put them out at £150 + VAT each
Sat Mar 09 2019 6:51pm |
