Home > Maintenance & Modifications > Check your oil there is no low level warning |
I have exactly the same as you Col, all works fine 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Thu Mar 07 2019 11:12am |
On my 2012 SDV6 have never had any issue. 10 mins after switch off the level can be checked. Still would prefer a traditional dipstick as well. I check it a couple of times a week. |
Thu Mar 07 2019 9:04pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 467 |
Did mine today,
Thu Mar 07 2019 9:32pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4858 |
I think you may find it will tell you how much oil to add if low, 1.5 litres is from min to max, if you add that amount because it just said low you may find it will give you a overfilled reading next time you check it.
Thu Mar 07 2019 10:09pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
If you check your oil level on the dash display it will either say “OK,” in this case you do not add oil irrespective of where the indicator bar is, or it will say “Add 0.5 litre” or some other figure. Then you do as it says. If you run the car without checking the oil and oil is required it will not warn you. You will never get a low oil warning in an RRS1 |
Thu Mar 07 2019 11:40pm |
Yes mine is fine
Thu Mar 07 2019 11:45pm |
