Home > Technical > what is this.... |
im going to guess that its a breather of some sort, but have often wondered the same myself. The top part unscrews. I wondered if it was a diff breather for when crossing deep water but could be totally wrong 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Mar 05 2019 9:33pm |
I’m sure it’s for getting the engine oil out with a pump. Andy.
Tue Mar 05 2019 9:35pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
Tue Mar 05 2019 9:36pm |
i was half hoping this is what it was for would be noce to have a little test point to look at the engine oil now and again.... the simple thinks in life 2007 TDV6 RRS HSE..now gone 2012 3.0 SDV6 RRS HSE |
Tue Mar 05 2019 9:39pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
It’s on a bayonet fitting and is for vacuuming the oil from the sump. Great way to change the oil, it takes about 5 mins to suck it all out with a good vacuum pump and 10 mins to complete the job with new filter too.
Tue Mar 05 2019 10:08pm |
every day is a school day! What would have been even better, if they had stuck a dip stick in there!!! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Mar 05 2019 10:15pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
Yeah. Look at ideal place to put some sort of stick down with markings on it. |
Tue Mar 05 2019 10:26pm |
Not sure anyone mentioned it being an ideal place to put one but something is better than nothing 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Mar 05 2019 10:38pm |
exactly! 2007 TDV6 RRS HSE..now gone 2012 3.0 SDV6 RRS HSE |
Tue Mar 05 2019 11:14pm |
good to know... but im happier seeing it flow out the sump plug 2007 TDV6 RRS HSE..now gone 2012 3.0 SDV6 RRS HSE |
Tue Mar 05 2019 11:16pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 387 |
You can see where the pick up point is once your under it. it's next to the sump plug so will extract all but the smallest amount of oil. and as we don't flush the engine oil then what does it matter if a small amount is left.... |
Wed Mar 06 2019 5:58pm |
