Home > General (L494) > Headlight Dazzle |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Anyone else get grief from other drivers about headlight dazzle? I’ve been flashed quite a few times now and notice that if the car in front is low (eg MX5), my headlights light up the interior. It’s also a problem when I brow a hill. As the car levels out I can literally see the opposing drivers blinded momentarily.
Mon Feb 18 2019 9:39pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 454 |
Yes,
Mon Feb 18 2019 10:07pm |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 |
Hi Hoppy, yes mine were too high and I adjusted them down. as Farmer Chalk says you use an Allen key. However, you need to find the correct screw . There are 2 sets of the white plastic looking screws.... one on the outside of the frame and one on the inside. the outside screws do side-to-side adjustment. to get to the inside screws for the height adjustment, you have to take off the black plastic cover pieces, small triangular sections, with the three plastic expanding bolts. Then look down inside and you will see the white plastic screws, you may need an extension piece on your allen key/screwdriver to get to them. anti-clockwise makes the beam go lower, from memory. best if you can be a fair distance from the wall or whatever you are shining against for adjustment, you do not need a lot - maybe one full turn , and if you are close to the wall you may think that you are not seeing anything happen. Be careful when replacing the black plastic cover pieces, the little expanding bolts are easily lost into the engine bay. MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
Mon Feb 18 2019 11:17pm |
Allen keys it is! Thanks all Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Tue Feb 19 2019 8:12am |
