Home > Faults & Fixes > HDC, ATPC, E-Diff, not available, ABS fault on L494..Help!!
Badgerfife
Hi. These warning lights all came on yesterday on my 50000 mile L494.
Just started running through warning sequences.
Drives ok.
Suspension ok.
Will not allow you to change terrain type/mode on control dial by gear stick
Any idea on possible cause? or approach to solve greatly recieved.
Thanks
Post #575276 Fri Feb 15 2019 6:34am
Heuerman
Low battery voltage? '10 Range Rover Sport TDV8
'97 Porsche 993 C2
'69 Lotus Elan S4
'63 E-Type Jaguar Open Two Seater
Post #575299 Fri Feb 15 2019 1:33pm
Badgerfife
Thanks. Just checked it. All ok. Popped in to have codes checked.
Will update when out.....eekkk
Post #575301 Fri Feb 15 2019 2:16pm
Brake light bulb. 2012 SDV6 - it's missing a couple of cylinders
Post #575302 Fri Feb 15 2019 2:31pm
Badgerfife
Update.
It was an ABS sensor wire and earth point.
Now running fine. Thanks for the suggestions.
Post #575627 Wed Feb 20 2019 10:21pm
nick09@live.co.uk
Hi I’ve got exactly same problem how did you fix ? Thanks
Post #601448 Wed Jul 08 2020 10:42pm
