Home > General > Fuel consumption sucks |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 156 |
Yep, that's pretty bad - my father has a 2.7 TDV6 Disco 3 and using it on farm/off-road it's about 23MPG and certainly never below 20MPG...
Fri Feb 08 2019 12:04pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
you should get 21MPG round town
Fri Feb 08 2019 2:39pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
Excessive fuel consumption is indicative of an issue somewhere such as a faulty injector. I sounds like it needs to be hooked up to look at live values for the injector trims etc. 2012 SDV6 - it's missing a couple of cylinders
humm.. should look at my offsets to see if 1 injector would improve it |
Fri Feb 08 2019 2:41pm |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 204 |
Yep, that's poor. Even driving mine like I stole it I get better than that. I regularly travel to/from Aberdeen from Newcastle, and usually get anywhere between 28 to 32 mpg. at home around the doors 21/23. You need some live data from an IID to see what the injectors are doing. Sounds like there's an imbalance somewhere |
Fri Feb 08 2019 4:44pm |
There are a number of things that could cause excessive fuel usage. The fuelling system on modern vehicles is pretty complicated. 2012 SDV6 - it's missing a couple of cylinders
Fri Feb 08 2019 4:59pm |
RobTDV6 Member Since: 31 Jan 2019 Location: Derbyshire Posts: 2 |
I’m wondering if it’s been remapped badly. It’s also a pig to start when it’s cold. The injectors were rebuilt not long ago. |
Sun Feb 10 2019 11:07am |
Glow plugs on the way out/failed if it's not cold starting.
Sun Feb 10 2019 11:41am |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Glow plugs can be a to get out without breaking them on older cars. Mine
Mon Feb 11 2019 12:27am |
More likely injector issues |
Mon Feb 11 2019 12:44am |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 |
I get the same mpg on my 2.7 around town. Always around there this time of year as the FBH works as well. Short trips every day, injectors checked and are good, so are turbo hoses ect, egr's blanked, 102,000 on the clock. Does the same as my old D2 did, so I don't worry. |
Mon Feb 11 2019 4:09pm |
